Evaporating Water
Hello everyone,
We plan to close the pool by the end of November and have been bleaching (down into the skimmer) it while also monitoring the pH. This is our first summer with our newly built pool and we have relied heavily on the conversation that occurs here on this forum, so thank you to all that contribute your time. Well, since I knew that we will close soon I have not refilled any evaporating water in the pool and now it is down about 4 inches below the tile (when normally it is supposed to be midway on the tile so that it goes into the skimmer). I am suddenly sensing this need to fill the pool, and yet it doesn't make sense when I will have to drain it right out again soon.
Is it o.k. for me to continue to allow the water to evaporate until we close it? Am I messing anything up underground?
Thanks ahead of time for all responses.
Shannon in VA
IG Pebble Tec 840 Sq Ft Rectangle
