Re: Adding Dry Ice to Pool
Yes, it was fun, but oh so educational...
If anyone wants to do this for Halloween, you could probably get by with 5 pounds of dry ice dropping in chunks when trick-or-treaters arrive. However, if you have lots of guests continually over many hours you'll need at least 10 pounds or more. You must use gloves (leather gloves work great) when handling dry ice as it is very cold and will freeze your skin if you touch it for more than a few seconds eventually leading to frostbite -- not as bad as liquid nitrogen, but not something to fool around with. See this website for lots of great info on dry ice.
Be sure to use a heavy old pan/pot -- thick metal, but not aluminum as the acidity of the water (from the dissolved CO2) might ruin the pan. If you don't want to use a hot plate, then just change the water when it gets cool and refill with hot water (hot tap water is plenty hot enough -- even warm water is OK).
I was actually (briefly) concerned that I was contributing significantly to greenhouse gasses by using dry ice so I did some calculations. Since the body exhales about 200 ml of CO2 every minute, this is about 0.36 grams per minute or about a pound per day. So using 20 pounds of dry ice is equivalent to having 20 people breath for a day. One gallon of gasoline produces around 20 pounds of carbon dioxide so using 20 pounds of dry ice is equivalent to using a gallon of gasoline or driving 20-40 miles depending on your MPG. There, now I've made you feel appropriately guilty, so have some fun and plant a tree (one tree absorbs around 1400 pounds of CO2 over its lifetime, mostly in the first 15 years of its growth).
Richard
I used to do this yearly on out front lawn, a witch with glowing eues, a couldren kept warm via a hotplate and a "fake" fire underneath, most parents were scared to step on out property, but that might have been because oif the lifesized "working" Guillotine i built which gets "remote controlled" by a friend hiding in the bushes - our display used to take up 2 front lawns (thanks to my old neighbours for the 2nd lawn) , now we're in the country with 5 acres and it takes up this little corner of our front lawn and is no longer as scary. Every year I build more, but I'll be 100 before I can get near filling THIS lawn!
Rotfl
You guys crack me up
Happy Halloween
Here's a picture of the cauldron after having a large chunk of dry ice just added to it. The "hand" coming out of the cauldron is a nice touch, don't you think? Boil, boil, toil and trouble!
So I tried leaving my pool open and the pH still stayed pretty much the same. I then realized that I could use my pool cover pump that normally pumps water off of the pool cover and could attach its output hose to a portable plastic shower that I have and put the pump into the pool (it's a waterproof pump -- essentially like a sump pump). I had to take off the shower nozzle because it gave too much resistance to the water and shut down the pump, but with the nozzle off I was in business. The stream of water hitting the pool surface from about 6 feet in the air has given enough bubbles and aeration to cause the pH to noticeably rise -- about 0.1 for every 8 hours of aeration starting from around 7.1
Though I could have just added some base, I thought I'd just try outgassing the same CO2 that I had added with the dry ice.
I hope everyone had a Happy Halloween.
Richard
Re: Adding Dry Ice to Pool - How to Aireate
Here is a cheap way to aireate. Take a washing machine feed hose (about 1/2" id). Remove the coverplate and eyeball on one of the return jets from the pump and dry the cover plate. Use a copious amount duct tape to tape the hose so that end will be near the center of the eyeball and extend into the jet of water about 1-2" - you may need to form the hose slightly with some hot water so it points in the direction of the water flow. Don't tape around the back of the plate or you won't be able to put it back on. Put the coverplate and eyeball back in and lay the hose on the deck or rail of the pool. When you turn on the pump play with hose until you get the maximum amount of air coming out. You just made an eductor. You'll hear the air being sucked in and see a large stream of very fine bubbles. With this I could drive my alkalinity down in hours. Looks hokey, but heh - free and take it out when your done. And NO, I'm not red-green.
