Closed Thread
Results 1 to 8 of 8
Thread: water level already back to normal with so much rain.....
    Honesdale PA
    Default Re: water level already back to normal with so much rain.....
    Whether you have to lower during the Winter or not depends on a couple factors...
    1--How low was it drained at the start of season
    2--How much precipitation do you get over the Winter.
    Personally I am in Heathers situation with a potentially high water table so I try and keep the pool water level as high as I can. Usually I start toward the bottom of the skimmer and try and not let it get above the top of the skimmer opening all Winter. This usually means draining periodically. Because it is usually a block of ice I do it in small increments, about 1/4" max, then let it sit for a few days before doing it again. Have to be real careful because of the ice block and the possibility of damage to steps and return jet penetrations. I likewise used a mesh cover but not anymore....too much of a hassle so it stays uncovered.
    Hope this helps.
    This is why my pool's still open!
    Actually, it's probably overflowing.....I won't be getting to it until all this rain stops, nothing's going to freeze for another 4 weeks anyways, then it's time to pump it down, remove the equipment and call it a day (well, actually we'll just call it an hour because that's all it takes).
    Any accumulation thereafter will just run out the open return and down a board I lean under it.
    Here in Canada, you really can't pump a pool down a couple of times over the winter since you can't pump solid water!
    I gouess you could get in/on your pool and shovel off all that excess snow, but you'd have to be real careful not to damage the liner with the shovel....once you have it shoveled, you can skate on it (unless you are using a winter cover) - once again - careful on the liner with those skates!
    Once things freeze, that's it, they usually stay in their frozen state until march sometime when it all melts, that's when you quickly close the valves and grab all that water to help top up the pool again (well, at least that's what you do in hte country where you don't have the luxury of endless amounts of water).
    Honesdale PA
    I forgot to mention that I have a couple 5 gal pails with another inside bucket loaded with marble rock as weight. Before the ice I float them and they sink except for the top few inches. When the ice comes I can take out the inside pail and pretty easily pull out the 5 gal pail. If necessary I pour a little warm water in the 5 gal pail to melt it loose. Bingo...an ice fishin hole and access to liquid water. With one in the deep end and the other in the shallow it also lets me jury rig my old extra pump to circulate if I need to before the ice melts. It's more psychological when the weather starts warming in the late Winter to kind of help the ice melt along.
    Mine froze solid last year (AG pool) - it may have had a little area in the center lower portion of the pool that was still semi liquid, but pretty much solid all through, it didn't help that we didn't get much snow which tends to help insulate a bit.
    I was going to say - do you stock your pool before winter? Why would you need a fishing hole???
    Honesdale PA
    Heh Heh...check my post in this thread.
    http://www.poolforum.com/pf2/showthread.php?t=5559
Closed Thread
