Thread: AquaLogic and Landscape Lights
    Default Re: AquaLogic and Landscape Lights
    Quote Originally Posted by SJohnson
    I may end up buying a new transformer anyway, not sure the one I have will run all the lights I have in mind.
    Thanks!!
    -SJ
    I DID get a new transformer. It needs to be hard wired into the control unit. Intermatic makes them (same company that makes Malibu low voltage lighting and also pool time clocks). you can check out their website
    www.intermatic.com
    I now have an extra plug in transformer that I am not using. it was the one that used to power my lights before the aqualogic. Both my electircian and my neighbor across the street who is a retired electrician said to go with the intermatic transformer and not cut the plug off of the one I had and wire it in.
    SJohnson is offline Registered+ Thread Analyst SJohnson 0
    Charleston, SC
    Thanks for clearing that up and thanks also for the lead on the transformer!! This just seems like the perfect solution with Aux2 not being in use and the timer functions in the aqualogic . . . Great to have everything on one control pad too!! You wouldn't happen to remember the model that you're using would you??
    Thanks again!!
    -SJ
    They have 2 models
    Here is the link
    http://www.intermatic.com/?action=subcat&sid=203
    I have the galvanized ones (3 of them...one for the pool light, one for the spa light, one for the landscape lights) but I wish I had the stainless steel ones
    http://www.intermatic.com/?action=subcat&sid=204
    since I live one block from the ocean and I have since heard that they will only last about 5 years here because of corrosion.
    Which model you need depends on the wattage of the lights you are hooking up.
    With landscape lighting bigger is usually better becuase you can then add to it without problems (At least in my opinion!) but then cost does figure into the equation.
