Results 1 to 10 of 13
Thread: Pool Timers - I need to replace
    Jul 2006
    SE Georgia
    Default Re: Pool Timers - I need to replace
    Sounds like you have an Intermatic mechanical timer.
    If I were you, I would save a bunch of money and go to Lowes and just buy another pair of mechanical timers. They're only $40 each. Here's the Lowes description: Intermatic 24 Hour Water Heater Timer, 250 Volt, Item #: 26399, Model: WH40-6-250V. I replaced mine last year. I didn't have to replace the box, I used my existing metal box and just used the timer mechanism out of the new timer. Easy!! The digital ones you are considering seem to cost about $150 each. For a timer - Ouch!
    40'x28' I/G L-shaped, vinyl liner pool, with an estimated 40,000 gallons of water.
    Been using BBB for over a year! Excellent results!
    Thumbs up Re: Pool Timers - I need to replace
    tc, welcome to the forum!1 If you remove the 'on' pin, is the tab still there? A cheep fix may be to just replace the 'on/ off' pins/ tabs.
    No clue about the electric ones (I'd probably electrocute myself trying to set one ) But it does sound like the 'flags' have deteriorated, so that they no longer trip the on/ off switches.
    Good luck on this, if you need any more help, never hesitate to ask
    Jul 2006
    Thanks for the suggestions. Yea, the digital ones are expensive but sounds like they would replace both timers as they seem to control two or even three items. Still would be twice what was posted about Lowes.
    I have tried the on off flags from the booster pump, still did not work. I will go to lowes and see what they got.
    Thanks again,
    Tom
    Honesdale PA
    Just something to consider about any electronic device, especially ones that are on an unfused, high current line. Lightening. Circuit breakers don't count as they are too slow acting. Unless you get a direct hit, the simple and cheaper mechanical timers are pretty immune. Manufacturers do consider power line spikes to varying degrees, but in any case, spikes and electronics don't get along well together. Another issue is wide temperature swings on electronic components if they are so exposed. I know they have a warranty but that is probably one year at most and anything after that, you eat it. Just my opinion.
    Jul 2006
    Good point. Had not thought about that. I can see the benefits of the mechanical timers: Cheaper, Robust to power flucuations etc, longevity.
    The electronic versions only have one real benefit: Progammability.
    Thanks for your input. I was hoping that someone that actually has used the electronic timers would have something to say, but I guess the lack of people that have used them on this forum makes a statement itself.
    Tom
    Gainesville, FL
    Cool Re: Pool Timers - I need to replace
    Quote Originally Posted by tclemmer View Post
    Tom
    I sell the tightwatt timers. Its a convenience thing. The good old Intermatics are fine too. Have you considered upgraded to automation with a wireless remote?
    -Jeremy
    I fix broken pool equipment
    Florida Leisure Pool & Spa
    www.FLLeisure.com
    Gainesville, FL
    Member APSP
    Member FSPA
    APSP Tech I
    Jul 2006
    I read some about the x10 home automation stuff but have not looked into any wireless stuff.
    I think I am going to save money and just look into a replacement mechanical timer.
    Thanks anyway
    Tom
  1. Pool pump timers
    By jeffyzf in forum Pool Equipment & Operations
    Last Post: 04-15-2012, 04:38 PM
  2. Pump Controller/Timers
    By bucky4835 in forum Pool Equipment & Operations
    Last Post: 09-03-2011, 01:35 PM
  3. SWG and filter timers
    By justawildchild in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-27-2007, 12:52 AM
  4. Texas Pool Timers
    By Pool_Mike in forum General Interest
    Last Post: 10-03-2006, 02:02 PM
  5. timers
    By Mcnown in forum Pool Equipment & Operations
    Last Post: 05-05-2006, 02:25 PM
