Results 1 to 9 of 9
Thread: Pressure problems
    Default Re: Pressure problems
    Valve settings will have an effect on filter pressure so try different settings to see if the pressure you noticed before was due to a particular configuration:
    Pool Mode
    Spa Mode
    Spill over Mode
    As I mentioned before, your turnover is currently about 4 hours. Most you would need would be 8 hours during the peak of the summer. Any reason you are running the pump 10 hours?
    1) 2 Speed 2 HP pump replacement. Reduce your power bill by 69% with 8 hour run time at low speed.
    2) 2 x 1 speed pumps. Re plumb 2 HP pump for Spa Jets only and purchase a 3/4 HP pump and plumb from for pool only. Reduce your power bill by 67% with 6 hour run time.
    3) Reduce pump run time for current configuration. Reduce your power bill by 20%.[/QUOTE]
    --Sorry, I don't know how to highlight your quote--
    I ran the pump 10 hrs/day based, I guess, on the man I bought the house from. I believe that's what he told me, though he may have been guessing just like me. That was before I found this website and discovered there are calculators to estimate pool volume and water flow and such as that. Concerning adjusting valves to influence filter pressure, I spent some time playing with the system and got the following indicated pressures: Main drain only-25psi Main drain50%skimmer50%-30psi Skimmer only-30psi Can't recall whether I pulled from the spa but that's something I rarely do. I usually just return about 40% through the spa to keep it flushed out. I don't have the waterfall type. Anyway, it seems I may have a blockage in the skimmer line. I'm afraid I'd have to cut the intake manifold to blow back through the skimmer.... Wonder if there's a way to pull the stuff back out through the skimmer?TIA Hal
    mas985's Avatar
    Pleasanton, CA
    I know it is counter intuitive but if your pressure goes up with the skimmer only, it means that there is less restriction via the skimmer and not more. Pressure is measured on the return side not the suction so it reads as the opposite for the suction side.
    It is typical in a pool to have the main drain have more restriction than the skimmer since it is a longer run and usually smaller pipe so you may be ok there. Before you cut any pipe, I would make sure you acutally have a problem. From what you have said, everything sounds normal to me.
    You will not get the PSI down to 12 unless you change your pump to a lower HP. Larger HP means higher PSI. I hyave a 1 HP motor and my pressure is about 20 PSI so I think this is probably normal for you.
    Also, it sounds as though you may be cleaning something out of the pool since it raises from 20 PSI to 30 PSI in a short period of time.
    Mark
