It is the salt level. The "good" range just means that there is adequate salt and that it is producing chlorine. I want to give it a chance to do it's job. I just wondered if the actual addition of the salt could be responsible for the color change - it was a pretty rapid change, faster than I would anticipate for a simple algae bloom.
Site owner -- www.troublefreepool.com
I saw no color change when I added the salt to my pool...
We had no color change either last week when our SWG was finally started. At 100% output for 24-hours, our SWG got the chlorine level well above 3.0 in our 10,000 gallon FG pool, but not nearly high enough to shock to clear an algae bloom.
Pool has cleared up. I used the swcg to shock to 24 hours and then had all chemicals checked - low on cya and calcium, high on pH.
Corrected levels and pool is blue and gettting clearer daily.
