Re: Pool finish faling?
New plaster pools always have plaster dust in the first few weeks of curing. If this is the first time you cleaned the filter since May, then that would explain the dust. It would also explain why you cannot clean it. Over such a long period, the dust will harden in the filter and be difficult to remove. If you can not remove the dust after soaking and spraying, then I would suggest a mild acid soaking to losen it up.
