Did a websearch for FAS-DPD and Aquachek test kit measures for chlorine and monopersulfate. Does monopersulfate have a more common name?
No, but I believe it's used for bromine pools.
You can happily and safely use a FAS-DPD Monopersulfate kit with your pool. You simply don't run the Monopersulfate test.
I have the Leslie's re-badged Taylor version.
Potassium Monopersulfate is also labeled as Non-Chlorine Shock and is sometimes called oxone (ox - own). It is a chemical patented by Dupont and is used primarily as an oxidizer. It is fast acting to rid Combined Chlorine in a pool or spa. It will increase/enhance the oxidizing ability of the chlorine in the water, but then reduce it back down to a safe level, usually within 15 - 30 minutes, so the kids can swim again the same day, rather than waiting for tomorrow.
Hope this has been helpful
Sean Assam
e-mail: [email protected] --- www.autopilot.com - www.aquacal.com
