Thread: What is monopersulfate?
    Default What is monopersulfate?
    Did a websearch for FAS-DPD and Aquachek test kit measures for chlorine and monopersulfate. Does monopersulfate have a more common name?
    Default Re: What is monopersulfate?
    No, but I believe it's used for bromine pools.
    You can happily and safely use a FAS-DPD Monopersulfate kit with your pool. You simply don't run the Monopersulfate test.
    I have the Leslie's re-badged Taylor version.
    Ft Lauderdale, Fl
    Potassium Monopersulfate is also labeled as Non-Chlorine Shock and is sometimes called oxone (ox - own). It is a chemical patented by Dupont and is used primarily as an oxidizer. It is fast acting to rid Combined Chlorine in a pool or spa. It will increase/enhance the oxidizing ability of the chlorine in the water, but then reduce it back down to a safe level, usually within 15 - 30 minutes, so the kids can swim again the same day, rather than waiting for tomorrow.
    Hope this has been helpful
    Sean Assam
  1. Using potassium monopersulfate shock when converting from Baquacil
    By Carolinakeepsakes in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-11-2012, 07:25 PM
  2. Pool Pilot and shocking with potassium monopersulfate
    By catnip in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-15-2007, 11:11 PM
  3. Potassium Monopersulfate shock
    By halds in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-26-2006, 09:09 PM
