Unfortunately I don't any good ideas for a mount. Perhaps some mount utilizing a return jet eyeball retainer to hold it where you want it or maybe mounting to the skimmer faceplate somehow. You could also put a dime sized vinyl patch over the wire to hold it against the liner. I don't need to monitor my temp constantly and when I do I just have a thermocouple taped to the end of a 1/2" PVC pipe a couple feet long and stick it where I want it. If the sensor is an exposed thermocouple junction you should coat it with silicone seal to prevent the chlorine from attacking the wires. Best I can suggest.
