Mine is installed after the filter but in the same manner as fcfrey. I suspect the PB installed it after the filter so that the thermocouple will not collect dirt as quickly as before the filter.
Mark
Thanks for responses. This is very helpful. I'm just concerned about drilling into PVC causing a leak. No problems with O ring leaking??
For plugging the drilled hole you can use a mixture of PVC cement and ground up PVC pipe to make a thick slurry. Squish it into the hole and let it set. I've used a rasp file to grind pipe or for finer stuff use a saw or a finer file.
Mark
My sensor has been installed in the supply pipe before the filter for five years now, with no leaking.
As mentioned in previous posts, the thermocouple came with an O ring. I take mine off every year when I close and lube the O ring with plumbers silicone. I have never had a leak.
Another method I have used is to carefully drill a 7/16 hole then tap with a 1/4 pipe tap, this allows you to use conventional pipe fittings & teflon tape to make connections. I used this method to install the injection port for my bleach injection system. Again ---- NO LEAKS.
