Results 1 to 8 of 8
Thread: Any connection between SWG and calcium deposits?
    Default Re: Any connection between SWG and calcium deposits?
    Quote Originally Posted by SoCalBoo View Post
    My pool has been very quick to change ph (upwards). I've always attributed that to the SWG. I usually need to add about a pint a day, and have needed to do so since startup two years ago. Now in the summer, when the SWG is turned up because of more chlorine eaten up by sun, I have to add more muriatic.
    Short and long of it is highly unusual for me to have a ph of anything other than between 7.2 and 7.5.
    Try dropping your total alkalinity to about 70 ppm, and when you add acid shoot for a pH of 7.6. You might find that this gives a a better pH stability with the SWG operating. Also, I have had excellent results by adding 50 ppm borates to the water. You can do this with such products as Proteam's Supreme or Bioguard's Optimizer but if you are cheap like me you will do it with 20 mule team Borax! See this thread:
    http://www.poolforum.com/pf2/showthread.php?t=4712
    Aslo, what type of SWG do you have? You seem to be running your CYA on the low side and this can also contribute to pH instability by causing the cell to work more than it really needs to. Most manufacuters recommed a CYA of 60-80 ppm (one I know of recommends 80-100 ppm and one I know of recommends 50-80ppm ) and there has been an excellent discussion on this board as to why this is most likely a good idea!
    http://www.poolforum.com/pf2/showthread.php?t=4495
    I test a lot of pool water every day i'm at work and have a lot of customers with SWGs besides having one myself. I see fewer problems in the pools that have the CYA in the manufactuers recommended range than in the ones that try to run it lower. This emperical evidence is enough to convince me that follwing the manufacturer's recommendation in this area is a good idea! Ditto on running the TA on the low side. I have found that when the TA is dropped to around 70 ppm the acid demend tends to go down. Chemgeek has given an excellent explanation of this in another thread
    http://www.poolforum.com/pf2/showthread.php?t=5379
    Hope this helps.
    SoCalBoo is offline Registered+ Thread Analyst SoCalBoo 0
    San Diego
    Waterbear,
    I've got a poolpilot digital. Love it. Works like a charm.
    I'll try running the TA in the 70-80 range. I'll also shoot for 7.6 on the Ph. I'll get some borates in the pool as well (by the way, what are 'borates', how do I test for them, and is there any website that can tell me how much 20 mule borax I need to add to get to the 50 level? will bleachcalc do it?)
    I've been running my cya kind of low for the swg to try and sneak up on the 'ideal' level and not overshoot. while I'm not having water chemistry problems per se (with calcium level where it is, I kind of expect to have deposits and have accepted that fate), I do recognize it could be better. so I'll try creeping up on 60ppm to see how I do. I believe the poolpilot digital sWG recommends 60-80ppm CYA. I was hoping to get by with a lower FC level...maybe I need to worry about this less and more about my TA/Ph/CYA, since I haven't had a measurable CC level in a longtime.
    Thanks again for the help.
    Waterbear,
    Bleachcalc has an error in the borax calc to achieve 50 ppm. The thread I posted above from the china shop "The Great Tetraborate Experiment" http://www.poolforum.com/pf2/showthread.php?t=4712 does tell towards the end how much 20 mule team and muriatic acid you need to add so I would suggest rereading the whole thread carefully. I know it's long but there is a lot of good stuff in it as Richard (Chemgeek) and I worked some things out!
    ... I do recognize it could be better. so I'll try creeping up on 60ppm to see how I do. I believe the poolpilot digital sWG recommends 60-80ppm CYA. I was hoping to get by with a lower FC level...maybe I need to worry about this less and more about my TA/Ph/CYA, since I haven't had a measurable CC level in a longtime.
    Shoot for about 70 ppm. People have gotten so afraid of CYA these days....from not thinking it was important if it got too high to almost thinking of it as the antichrist and an evil that needed to be avoided at all costs! he benefits will be longer cell life, less energy consumption, more stable pH (and therefore less possibiblty of scaling conditions occuring), no 'dead spots' of understantized water, etc. How about we trust the manufacturers for once. They might actually have a clue as to how their product is supposed to work!
    Hope this is helpful!
    Evan's (waterbear's) advice is excellent and will address the pH rise you are seeing and the amount of acid you have been adding. The part that doesn't make much sense to me are the calcium deposits on the spa spillway tile. With the numbers you posted I did two things (in my infamous spreadsheet) to see if I could figure out when scaling might occur. I first used a high spa temperature of 104F since higher temperatures lead to more scaling. Then I saw what sort of pH would be needed to get scale and though "balanced" water would have a pH of around 7.3, scaling normally wouldn't occur until you got to nearly 7.8. And yes, the indices that calculate this stuff are controversial so enough said about that.
    So I have two thoughts about this. First, is when you startup in the spring, if you are willing to experiment then before you lower your TA and add Borax see when your pool/spa is adding deposits again. Then, test your spa water when this occurs. Perhaps the aeration and high temps of the spa have raised its pH quite high. If that is true, then the things that waterbear suggested should help reduce the scaling problem. Of course, even if you test and things look normal, waterbear's advice is still good to slow down the pH rise and reduce your use of acid and should be tried anyway to see if it eliminates this scaling problem.
    My other thought is that perhaps this isn't scale but is something else. At first I thought it might just be evaporated salt, but this is a spillway and not splash-out on coping. Anyway, those are the random thoughts I had...at least you've got a good plan from waterbear that is sure to address some and probably all of the issues you are having.
    Richard
    San Diego
    HMMMM. Interesting. I will tell you that I haven't used the spa much at all recently. In fact, if it gets used more than one a week during summer, and one a month during winter, it is a rarity.
    See above. doubt we've got a temperature issue worth mentioning. right now, spa and pool are a crisp 52F. However, it is true during summer that both pool and spa are in high 80s around clock.
    Pretty darn certain it is scale. evaporated salt would come off tile much easier, and would likely do so with just scrubing and pool water. this stuff takes a fair amount of diluted acid (don't worry, I'm careful...did a lot of chem labs in college, so I know what the stuff can do if you are not careful). the scaling also occurs in a few other areas, notably a few nooks and crannies just above the water line where circulation isn't great. with my calcium getting higher...I just assumed it was scaling.
    Richard
    Thanks all
