I thought of another possible reason why SWG manufacturers recommend high levels of CYA (typically 70-80 with 80 "best"). In this thread (starting at around post #30) I said that the reason for high CYA in SWG pools is that this is more efficient at producing chlorine. Though this appears to be true (based on pool owner's experiences with runtime), I didn't say what happens when there is a buildup of chlorine at the plate. In addition to production of chlorine, there is also a competing reaction of producing oxygen. If the reaction producing chlorine slows down, then the reaction rate of producing oxygen can speed up in its place, though the production of oxygen is normally less favored than that of chlorine (technically, the production of oxygen is more likely to occur in an equilibrium sense, but it has a much higher activation energy than the production of chlorine so results in an overvoltage such that chlorine is more favored than oxygen).
It is interesting to note that different SWG systems use a different voltage to drive their cells. Some operate in the range of 6-9 volts, but others are in the range of 22-30 volts. Though the voltage level required to only produce chlorine and not oxygen is quite low (perhaps between 1.16V and 1.45V at normal pool concentrations of pH and chlorine), higher voltages will probably produce both chlorine and oxygen with chlorine being produced more. I do not know if higher voltages change this relationship, but suspect that it might, with the oxygen proportion increasing somewhat at higher voltages (though still produced in lower quantity than chlorine). At any rate, having lower CYA levels may very well increase the oxygen proportion and this can be dangerous since the other plate is producing hydrogen. Though hydrogen by itself is not explosive and in water does essentially nothing, the combination of oxygen and hydrogen can be dangerous if this combination of gasses were to accumulate (if the pump shuts off but the SWG cell keeps running, for example).
The blog link at the first post in this thread has been reporting some explosions of SWG systems and I wonder if those pools were using lower CYA levels than recommended and produced more oxygen that could have been at explosive levels with hydrogen. It is also possible that the explosions weren't actual ignitions of hydrogen and oxygen, but high pressure bursts from the buildup of gas pressure. It should be understood that under normal operating conditions when the SWG only operates when the pump is running, that the risk of explosion is virtually nil. I'm just trying to sort out some unusual circumstances (where the salt cell didn't shut off when the water flow stopped) to better understand what is going on.
[EDIT] A further note: Even the most dangerous levels of hydrogen gas and oxygen gas in a 2:1 ratio will not spontaneously explode unless the pressures are very high (much higher than what pipes would handle, so bursting would occur before explosion) or the temperatures are very high (at least 400C) so generally some sort of spark or flame is required to trigger a literal thermal explosion. In other words, the risk of oxygen production and explosion is low; the risk of a pressure burst is high if the salt cell operates in a closed valve environment (which would only occur if some component failed to operate properly). [END-EDIT]
Richard
