Results 1 to 10 of 15
Thread: Electrical Question
    y0manda is offline Registered+ Thread Analyst y0manda 0
    Default Electrical Question
    I'm going to install an outlet for a friend in his backyard and he is going to run a 15amp pump for his koi pond. My question is can I use 12AWG wire for the 130' run from the panel off an unused 20 amp circuit? Also he may use the new outdoor outlet for other things like a 300 watt low voltage lighting transformer. If you do recommend a 10 AWG wire what size circuit breaker should be used. Thanks.
    Default Re: Electrical Question
    Whatever you do, be SURE the circuit is ground-faulted AT THE BREAKER BOX IN THE HOUSE! Do NOT rely on a GFI outlet--it needs a GFI breaker.
    12 awg for 130 feet is fine.
    Leander Texas
    Carl,
    What has been your experience to recommend not using the GFI at the outlet? I thought that as long as the outlet was well protected from weather that it would be good enough. I have an electrician friend that said the breakers were a pain and the outlet type would be fine. Granted he climbs poles and deals with high voltage everyday but I trust his word. Please tell me your reasons as I sure don't want the kiddo's to fry by accident.
    Cornelious 16x26x52" AG
    Hayward Matrix 2spd 1HP 110V Pump
    Old Junky Sand Filter
    Jacuzzi Landslide 55 DE Secondary Filter
    1-1/2" Dow Pink Foam Bottom W/Foam Cove
    I think the idea of the breaker is to protect the whole system from the main breaker panel all the way out to the outlet. If you just use a GFI outlet and have a problem in the wiring (digging accident or whatever) your GFI outlet won't sense that and the wire will still be hot.
    Let's be precise. By breaker we don't mean a regular circuit breaker, but instead a GFCI circuit breaker. Given that clarification MarkC's reasons are the same as mine. The WHOLE circuit is ground-faulted, not just the outlet.
    But I'm not a bonded electrician, not even an electrician. Why does your friend call them a pain? Is it that they are a pain to install or that they are unreliable? If it's the former, well that's too darn bad--I've installed them myself and they usually take up 2 slots for one GFCI breaker, instead of one. If it's that latter, I'd like to hear about the problems.
    But he/she is your friend. You have to choose who's advice you take, and why.
    Leander Texas
    Mark & Carl,
    I appreciate your answers. I didn't even think about the 125' run underground and the GFI not working the whole distance. We have already had our doofus Golden Retriever dig up the wire once and start chewing on it. If nothing else it could save the bonehead from being fried if he does it when no one is home to catch him.
    Thanks again and as always the input from the board is AWESOME!
    Cliff
  1. Pump/motor electrical question
    By tomdow2 in forum Pool Equipment & Operations
    Last Post: 05-21-2007, 03:10 PM
  2. Electrical question
    By mohawk in forum Pool Equipment & Operations
    Last Post: 02-21-2007, 06:14 PM
  3. Electrical Bonding
    By dave orso in forum In-Ground Pool Construction and Repair
    Last Post: 11-06-2006, 01:34 PM
  4. pool lighting/electrical question
    By ryanm in forum Pool Equipment & Operations
    Last Post: 07-04-2006, 07:04 PM
  5. Electrical SWG
    By Jeffery in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-05-2006, 06:21 PM
