Since high strength liquid chlorine is rather unstable, and I just bought a carboy of 12.5% yesterday, I wanted to see if it was truly 12.5%
We know, from the Bleach Calculation formula, that 1 gallon of 12.5% Liquid Chlorine will add 12.5ppm of FC to clean water (ie, with nothing to metabolize).
1 gallon contains 128 fluid ounces and one centiliter (10 ml) equals .34 fluid ounces.
Therefore, if you add 1 ounce of 12.5% to 78 1/8 gallons of water, you should get the same 12.5FC reading.
0.34 time 78.125 gives you 26.56 gallons. Therefore 10ml of 12.5% liquid chlorine should get the same 12.5FC reading in 26.56 gallons.
Divided by 5 and 2ml of liquid chlorine should get the same reading from 5.3125 gallons.
Adjust down for 5 gallons exactly, and 1.88ml of Liquid Chlorine should keep that reading.
So, if you pour 1.88ml of bleach/liquid shock/liquid chlorine into 5 gallons of fresh water, you should get the same FC reading as if you dump 1 gallon into 10,000 gallons of water.
On Ben's PS-232 kit, the OTO/pH cell has a side marked to 1.8ml. I used that to check my work. It wasn't as precise as I would have liked because I goofed and added the 1.8 and a little to 5 gallons of pool water![]()
I got a reading of 19.5 FC. Then I tested the pool water and got 5.5, indicating that my 12.5% was 14%--I AM dubious that it's stronger, but at least it tells me the 12.5% hasn't started to degrade. I'm recycling a lot of bleach jugs...Filling them halfway with tap water, then the rest of the way with 12.5%--it should give me gallons of 6% that I hope is more stable.
I would VERY much appreciate somebody checking my math and my assumptions.
Thanks!
