Results 1 to 10 of 21
Thread: Why is my pool so dirty!!!
    Default Re: Why is my pool so dirty!!!
    Remember that TA is composed of all alkalinity, both carbonate alkalinity and the alkalinity from CYA (and other lesser components) so even 70 ppm TA is risky if the CYA is high (i.e. 70-80) while at a lower CYA of 30 ppm then 70 ppm is OK. A 50 ppm TA even with a low CYA of 30 ppm, is on the corrosive side (not terribly -- just my being picky), and though this can be mitigated by running a higher CH and a higher pH, I would only do that if the rising pH was a really bad problem. At 50 ppm TA, a CH of 400 and a pH of 7.6 (instead of 7.5) would be better.
    Richard
    Richard,
    I opened my pool this season and am in the process of lowering the TA to 70 (as mentioned above). One number that changed over the winter season is the CH which is now at 175. I have purchased 8 llbs of Calcium Increaser from Walmart which should raise the CH to approx. 200. Should I raise it more or keep it there. My guess is that CYA is at appox 20 (dot never disappears completely but FC has not diminished too quickly). What do you think? As always, thank you.
    Alex
    If you want to have your pH closer to 7.5, then I would raise your CH level to around 300 ppm. Otherwise, you could just run your pH around 7.7 at your current CH level of 175 and be fine. It's not a big deal either way -- I'm just letting you know what is closer to ideal. Having your pH target at 7.7 would result in even less rise in pH, but if you don't see much of a rise at 7.5 and want that as your target instead, then the higher CH level would be better (but not a huge problem if you didn't do it -- the saturation index at pH 7.5, CH 175, TA 70 and CYA 20 is about -0.3).
    Richard
