Re: Salt Levels
I also have a DIG-220. Right now my water temp is around 47, so the control panel has dropped cell output to 1%, and the salt reading is 300 ppm lower than my Taylor test kit results, which I trust. As Richard says, typically cold water will give you a lower reading than actual.
If you're just setting up your system, you may need to "calibrate" the cell. This is done by taking several measurements and then manually entering the value into the Control panel. See your manual or the Poolpilot web site for more detail.
I'd trust your manual test results for salt level for now. Keep the BBB method in place until you get closer to swimming temp. By then you can trust the Pool Pilot display to be closer to reality and do the calibration. Hopefully PoolSean will see this thread and add the expert opinion.
Nater
