Results 1 to 10 of 12
Thread: Pump run-time in the Central-Texas winter?
    Central Texas
    Default Pump run-time in the Central-Texas winter?
    I'm not running the pumps (Main and Polaris booster) very much these days, mostly just to get a few leaves off the bottom every other day or so. Also on the few nights where the temperature drops into the twenties for a few hours. The water is clear and is probably just above freezing - it hurts to put my hands in the skimmer to remove the basket. Chlorine demand is way low.
    For the next two months I'm thinking I can go at least three days between running the pumps for a while, other than the freeze-protection runs. As long as the water is staying clear, is there a reason to keep running the pumps every day or two?
    Tom Wood
    15K IG Plaster, Sand Filter, Polaris 180
    Default Re: Pump run-time in the Central-Texas winter?
    As far as I know, the only reasons to have circulation of water are:
    1) To distribute chlorine (and other chemicals) evenly to prevent low concentrations in parts of the pool (usually caused by chlorine getting used up by algae trying to grow in such regions) so that algae growth is prevented.
    2) To move large objects (e.g. leaves) to the skimmer for easy collection.
    3) To filter the water to remove suspended particles (i.e. to prevent cloudiness).
    4) To prevent freezing of the water, mostly in pipes (only during freezing weather, of course).
    With extremely low temperatures and a lack of strong sunlight, the risk of algae growth is very, very low. I don't know if there is an easy way to tell how much circulation is good enough except to see if algae starts to develop. Even if it does, its growth would be so slow as to be easy to see and remove with more chlorine. It seems to me that it's just an experiment for your pool, but that the risk is low.
    My own pool only gets down to around 50F this time of year so I still have my pump running every day, though only for 2 hours. This is probably overkill, especially since the pool has an opaque cover, but it's what I'm comfortable with.
    Richard
    Central Texas
    Thanks Richard,
    That's what I figured. This is our first year (since April 2006) with our first pool so we're still learning how to manage it under the various weather conditions. The previous owner gave us a quick course on the pool and actually ran the pumps more in the winter. It turns out that pretty much everything else he said about the pool was wrong, so this is just more of the same.
    Tom Wood
    North Florida
    Hi Tom,
    I'm really interested in your post. I'm in north TX and am in my first winter with an open, uncovered and unheated pool. I've probably been too hesitant to drop my pump time but would LOVE to have the energy savings as long as I don't develop algae. Currently, I'm running 6 hours per day in 2 sessions (2+4) plus additional time when the freeze protection kicks in. My pool temp was 46 this AM and has been in the mid-40's most of December, with a low of 40 and a high of 51. Pool is in full winter sun, super clear, and with a chlorine demand running 0-1.0/day (SWCG off due to water being too cold).
    When you do run your pumps for circulation purposes, how long are you running them?
    Thanks for the help.
    Sandy
    Central Texas
    Hi Sandy,
    I'm running it just enough to keep it looking nice since it's in full view out the back patio doors. A couple of hours usually takes care of it, plus a little time with the net. I'm going to experiment with leaving it off as long as possible and see what happens. I haven't really measured the water temperature, so it's probably closer to yours since it's also uncovered and unheated.
    I go to www.weather.com and look at the 24 hour forecast to see when the temperature is going to drop into the twenties, and if it's late at night I'll set the timers accordingly.
    It has low CYA - probably around 20ppm by now, so I can run relatively low chlorine, usually around 2ppm. I use bleach and then a little muriatic acid to control pH.
    Tom Wood
    North Florida
    Thanks for the info, Tom. Like you, our pool is very visible from the house which entered into our decision to keep it open for the winter.
    Since reading your first post, we've had temps in the 20's overnight, so the freeze protection mechanism kicked in automatically. That's great, but it meant that we had a lot of time running the pump. So, I've been manually turning off the "normal" run times. I guess I need to do some experimenting as well, since it appears I could do just as well with a lot less regularly scheduled pump time in the winter.
    Really glad you posted your initial question.
    Sandy
