Results 1 to 10 of 12
Thread: Pump run-time in the Central-Texas winter?
    Central Texas
    Default Re: Pump run-time in the Central-Texas winter?
    Hi Sandy,
    I'm running it just enough to keep it looking nice since it's in full view out the back patio doors. A couple of hours usually takes care of it, plus a little time with the net. I'm going to experiment with leaving it off as long as possible and see what happens. I haven't really measured the water temperature, so it's probably closer to yours since it's also uncovered and unheated.
    I go to www.weather.com and look at the 24 hour forecast to see when the temperature is going to drop into the twenties, and if it's late at night I'll set the timers accordingly.
    It has low CYA - probably around 20ppm by now, so I can run relatively low chlorine, usually around 2ppm. I use bleach and then a little muriatic acid to control pH.
    Tom Wood
    15K IG Plaster, Sand Filter, Polaris 180
    North Florida
    Thanks for the info, Tom. Like you, our pool is very visible from the house which entered into our decision to keep it open for the winter.
    Since reading your first post, we've had temps in the 20's overnight, so the freeze protection mechanism kicked in automatically. That's great, but it meant that we had a lot of time running the pump. So, I've been manually turning off the "normal" run times. I guess I need to do some experimenting as well, since it appears I could do just as well with a lot less regularly scheduled pump time in the winter.
    Really glad you posted your initial question.
    Sandy
    Central Texas
    Well, it's been three days now and it looks fine to me. Since my regular maintenance includes adding muriatic acid on Wednesdays and Saturdays, I think I'll run the pumps only on those days for a while, except for freeze-protection runs.
    Tom Wood
    Central Texas
    The pool did fine with a Saturday/Wednesday only to run the pumps. We're about to have a week or more of nasty weather with lows in the low 20's and daytime highs in the mid to upper 30's, so not really a hard freeze. To be safe I took the drain plugs out of the pumps, opened the pump basket and set the multi-port valve to an intermediate setting so it's open to air. Today I just dribbled some bleach around the edge and used the leafnet to stir the water. I'm betting this will work for several weeks.
    Tom Wood
    Central Texas
    Now that our ice storm has melted, I put the plugs back in and turned the pumps on for a while to get the leaves out of the water. All working fine and very little need to add chlorine or acid. The storms tend to blow through here about once a week for the next several weeks, so taking the plugs out that often isn't really a chore. I discovered they are plastic and hold their seal even if finger tight, at least for a while.
    Tom Wood
    Central Texas
    Dunno if anyone is still reading, but I let it go two weeks without a pump run, and other than a collection of small debris on the bottom the pool did fine. I've run it for a few hours over the last couple of days just to clean up a bit, but I'm pretty sure I could have let it go indefinitely until spring arrives. Our electric bill has dropped significantly and I'm going to turn back the summer runtime too.
    EDIT: My recent maintenance consisted of adding a little muriatic acid and bleach twice a week (amount based on either testing or prior experience) and then using a leaf net to clean the water surface and to stir the water.
    Tom Wood
    joelq is offline Registered+ Thread Analyst joelq 0
    Frisco, TX
    Hi - for what it's worth, I live the the Dallas-area, and I've been running my pool 1.5 hours everyday, and that seems to be enough to keep the water sparkling. I did throw in about 1/3 gallon of bleach the other day (11k gallon pool), just in case, as my FC was down to 0.5 ppm.
