Re: New pool build -- pipes and pump sizes
I know each skimmer is a separate 1.5" line, and the drain is separate but I'm not sure if it is 1.5" or maybe larger (it is also an MDX drain so it has a single floor drain and side wall drains so the way that ties in I don't know).
So I guess that is kind of my question. Is 1.5" still bad if you have at least 3 separate lines to the pad for your suction? You get the sense that pools are built somewhat differently in different parts of the country and I just want to make sure that I am focusing on real issues -- because there are plenty of other things to worry about in a pool build.
The pump thing does seem off. Although if you had a big pump and big lines and you could do your 1 to 2 turns in less time is it really all that much worse? I guess it is better to have longer times of circulation at lower rates. While the non-HP centric Intelliflo seems like it could get me out if some of that, I worry if everyone here builds normal pools oddly how will they handle next generation stuff?
