Consider how long you want to heat your pool also. Year around pool use may not be practical if the outside air temps are into the 20's and 30's. Who realistically goes out in a bathing suit when it's that cold?
We've successfully installed heat pumps in the northeast US for many years. Again, there are limitations as all heaters will reduce efficiency when it gets cold. However, you should know that the most efficient gas heaters (forced air induction types) are about 90% efficient, with most of the rest of the gas heaters being about 70% efficient. That reduces the amount of BTU's being produce.
The 100,000 BTU's of gas that you're paying for is only giving you 70,000 BTUs (or 90,000 BTUs with the efficient gas heaters) in return.
Heat Pumps give you 500 to 600 times the investment cost to heat the water and are the most cost effective for consistent heat.
Solar is even more efficient, but is inconsistent on overcast or cloudy days, or operated at night time.
To look at it another way, you can actually afford to KEEP your pool heated using a heat pump for less than the cost of a gas heater being used to heat
it on demand (when you want to use it). The pool is always ready for swimming with a heat pump.
Benefit to gas? Because you can get gas heaters with copious amounts of BTUs, 400,000 BTUs for the largest residential gas heater, you can heat the water faster when you want to use it.
As ChemGeek mentioned, a solar cover is a worthwhile investment, if you use it. Most pool owners, depending on the size of their pool, will used a solar cover the first month, but then decide to just leave it off to avoid the hassle.
Venting with a gas heater is very important and I support the cautions that ChemGeek mentioned. By the way, that's where the other 30% of inefficient heating BTUs go, out the vent in wasted heat.
Hope this helps.
