MOST heat pumps quit below 60 degrees. Because of that there is an option of "heat and cool" in which it will reverse the flow of freon to defrost the ice that forms on the side of the heat pump to stop it from working. Some do this automatically and some require a manual switch. Aqua Cal has this built into the Heat N Cool models and will work down to 23 degrees (albeit at a lower efficiency).
