Results 1 to 3 of 3
Thread: basic chemicals???
    Mojo1 is offline ** No working email address ** Mojo1 0
    Jul 2006
    Default basic chemicals???
    Right now I have a service that takes care of the water, chemicals only ,I do the cleaning. I want to start to do it myself and need help on what chmicals I should buy right of the bat.Its an inground pool about 18,000 gallons, and not a salt pool. Also has a hot built in if that matters. Thanks for any input for a new guy, I did a search and found nothing ?
    Northern Kentucky
    Default Re: basic chemicals???
    Check out the sticky topics at the top of this thread, especially "BBB method, what is that". Most here don't use the typical chemicals. We use Bleach borax and baking soda. Read all of the stickied topics, and as much as you can of the rest of this forum.
    You will need a good test kit, such as the Taylor K-2006, available online and relabled at leslies. Many here can help you better than I... I just tried to give you a starting point.
    Read, Read, Read!
    ~Grace
    Avid reader of this forum
    but alas, no pool... yet!
  1. next step on my basic controls
    By vinper in forum Pool Electronics
    Last Post: 08-18-2013, 08:57 AM
  2. old basic bleach calculator
    By Oclat in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-29-2010, 12:57 PM
  3. Basic Pool Cleaning -- What do I do?
    By subedoo in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-02-2006, 01:33 AM
  4. Basic 27' above ground....quotes??
    By Kenny H in forum In-Ground Pool Construction and Repair
    Last Post: 07-15-2006, 11:40 PM
  5. Some Basic Questions
    By sock monkey in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-14-2006, 10:21 AM
