Re: CH Test Question
Your CH is fine. In fact, you need a higher CH in a salt pool both due to the higher TDS, but also due to the fact that with the higher CYA your TA is composed of less carbonate alkalinity (also, you may want to lower your TA to 100 or 90 at some point if you find that you are fighting rising pH and adding acid frequently). So your 420 ppm level is great.
Normally, when the temperature drops, the pH will rise, so I am a bit surprised that you are at 7.5 pH. If you started there at 80 or so degrees, then you should be at around 7.7 or 7.8 now. That would have your water be a little less corrosive than it currently is -- not a big deal, especially with lower temps, but just letting you know that you could increase your pH if you want and it should find it's way back down again as the temps come back up in the spring. If you don't have a cover, then maybe your pH is slowly rising anyway so you can just let it do that if you want.
As for the CH and other tests, though ideally you add drops and mix simultaneously, I have not found any problem just adding a whole bunch of drops and then mixing, especially in the beginning when you know that you will be needing to add a lot. As for the mixed endpoint you are seeing, it should be blue overall, not with specs of red. Typically, adding drops in the beginning (before you add the calcium buffer and that you count in your final count of drops) is to prevent a "fading endpoint" which looks more like something that is blue that then turns back into red after a few seconds. So I'm not sure what these red "specks" are that you talk about. You can try adding more drops in the beginning to see if that helps.
With your CH level, you can also use the 10 ml sample size instead of 25 ml and then multiply your drop count by 25 instead of 10 (you use 10 drops of calcium buffer instead of 20 and 3 drops of indicator instead of 5). Not quite as accurate, but for the CH test, this really doesn't matter much as a change of 25 is not very large at the levels we deal with in a pool.
Richard
