Re: Frog mineral systems
FROG Report...
As an FYI this is my first full year with the FROG system and I have to say I'm pretty pleased with it. While a couple of my neighbors (without the frog) have each had a couple of rounds of algae and cloudy water and they've spent money and time clearing things up, mine with the FROG has remained crystal clear all summer. I've only had to keep the chlorinator full and I've added a little supplemental liquid cl (about 3 gallons between May 1 and July 5).
I only hope I can find the mineral pack for less than $100 next year. I also plan on using my own 1" cl tabs by refilling the empty packs that frog sells for $20 each.
18x36 IG vinyl
24k gallon
Sand filter
