It's actually a money pit in the backyard disguised as an in ground vinyl liner pool by Kafko. It has two drains about 2 feet apart, one skimmer, four returns and two lights. It was installed by a professional pool builder, Sunbuilt Pools, but he blew us off near the end and was apparently aware he was going out of business. I think he also realized he screwed up the pool and had to custom order another liner.
The pump is malfunctioning, the heat pump doesn't work, and it loses about 400 - 500 gallons of water a day. I don't know where it's leaking from, but it doesn't appear to be related to the skimmer or skimmer plumbing. I can't find anyone in the Marble Falls, Texas area willing to come look at it since they didn't build it. I have no idea where the leak could be and it's way to cold to get in the water. I'm letting it go down, hoping it will stop so I can see where the leak is. I'm afraid to let it drain out completely so if it passes the returns and light niches, I'm going to start putting water back in.
One thing is certain, if I could do it over, I would not get a vinyl liner pool!
