Results 1 to 9 of 9
Thread: Leaking pool
    Default Re: Leaking pool
    Thanks for info! I'm watching it close and it seems to be leaking at about the same rate, but it hasn't fallen below the returns, lights or stair bottom. I put some food coloring in around all the suspect places but it didn't seem to be drawn in at any of those places.
    How could this much water leak out the bottom of the liner with the pool crete there? Wouldn't the water get pooled between the poolcrete and liner?
    Also, since I've lowered the water I noticed there are 3 rust spots around the pool where the liner is attached to the coping. The rust seems to have blead through. Could this be rusting screws below the coping? Is there a safe and effective way to remove the rust stains?
    As I mentioned, the pool is only a few months old, but I guess I have no warranty since the pb is out of business.
    Flowery Branch, Georgia
    Im sorry you are having a problem...but i have a Kafko brand liner pool and mine is fine. We didnt even close it for the winter. It was done in August of this year. The only 2 problems we have had was with the polaris pump leaking, and the timer box didnt work right. This is our second liner pool. Our pool is 16 X 32 Oasis model. 1 skimmer, 1 drain, 3 returns. Took 7 weeks to get done.
    We had a hard time with our installer as well. I think they got real busy and just sorta blew our pool off because it wasnt a gunite or as expensive as some of the other pools they were doing....I got into so many arguments with the owner that he didnt even turn the pool over to us. A worker did.
    This is the company we used..http://www.fun-n-sunrecreation.com/
    What a coincidence. We we're going to get the 16x32 Oasis, but decided to switch to the 20x34 Tahiti. Only problem, the pb messed up and put in the wrong pool, then called it a "custom." We think he realized the mistake sometime during the installation, but tried to play it off until we started asking about dimensions.
    Did you get a copy of the dig spec's with your Oasis? That's the engineered drawing that shows all of the dimensions. We couldn't get ours, either from the pb or Kafko.
    Thanks.
    We got our dig specs..i have them somewhere....
    I have been pretty happy with our pool so far....knock on wood.
    Our pool bottom is not the smoothest at the break when the light is on at night, but oh well.
    We have polaris fountains that i can turn on to move the water so you cant notice it at night unless everything is off and the light is on.
    I have the medievil tile mist liner. We have a round gray step and a gray swim out step. No ladder or hand rails.
    Do you know if your pool is actually 16' at the widest point? We too have the same liner.
