Results 1 to 10 of 10
Thread: Cold weather!!!
    salinda is offline Lifetime Member Weir Watcher salinda 0
    San Jose, CA
    Default Cold weather!!!
    In Northern California, no one does a winter pool closing. We simply decrease the pump run time significantly, drain/isolate any solar system, and let freeze protection work occasionally. Well folks, this is a weird winter so far. The freeze protection has gone on every night for at least the last two months.
    It is almost 9 am and the air temp is still low enough for freeze protection. All of my hose bibs are frozen. Water poured onto the concrete patio freezes on contact. It feels like NY, where I grew up.
    I checked the water temp and the Jandy says it is 40 degrees. Is this high enough for the freeze protection to be effective? In a normal winter, the water rarely goes below 50 degrees. The run from my pool to my equipment is somewhat long and I don't know how deep the piping is buried because I didn't build this pool.
    The cold weather is not expected to break soon. Should I be adding something to the water to lower freeze temperature? My pool is a salt pool, so that should lower the freezing temperature slightly already.
    Maybe I should just relax and let nature take its course....
    Salinda
    owner of ~35,000 gallon plaster IG pool/spa combo. Ikeric Dyna-Miser VS150 filter pump, 2 hp whisperflo spa jet pump, The Pool Cleaner 2x suction cleaner, Clean & Clear Plus 520 cartridge filter, Zodiac Clearwater LM2-40 SWG, Sta-rite 400k heater, solar heat pads and coils.
    DONNIE is offline Registered+ Thread Analyst DONNIE 0
    Jul 2006
    Oklahoma
    Default Re: Cold weather!!!
    If its any consolation it was 9 degrees here last night. My pool is not winterized and it's uncovered. I have been running my pump 24/7 and the water temp is below 40F. Right now there is 4" of sleet surrounding it. My fountain gets a large icecicle on it that I have to knock off every 24 hours but other than that all seems fine. I was worried sick about the freezing weather but now I know what my plumbing can endure.
    Donnie
    9000 Gallon Fiberglass IG / Sta-Rite pump,cartridge filter & heater / PoolPilot Dig 220-36 SWG / Testing w/K2006
    Central Texas
    I gave up trying to manage the equipment runtime to avoid freeze damage. I took the drain plugs out of the pumps, opened the pump basket, and set the multiport valve to an intermediate setting so it is open to air. Our lows may go into the low twenties, rarely to the teens, but doesn't stay there long so it's not a hard freeze.
    It is however now snowing here in the Texas hill country, and that's rare.
    Tom Wood
    15K IG Plaster, Sand Filter, Polaris 180
    North Florida
    I'm probably located between DONNIE and aquarium. I have an open, unheated, saltwater pool. The norm here is to keep pools open.
    Our low last night was also near the single digits. Our last above-freezing temps were sporadically on Friday, all below freezing since with the major ice storm that came through. My freeze protection has kept the pump on 24/7 since Friday morning . I've also been running the booster pump constantly. My filter has insulation wrap around it (made me feel better) and there's a styrofoam water spigot cover over the pressure gauge. The water temp was down to 40 two days ago and about 39.5 yesterday (haven't ventured out to check it today).
    We had a bit of melting yesterday in the sun, even with below-freezing temps. Hopefully, we'll see more sun today and maybe get to 33 degrees.
    As long as we don't lose power and the pumps can still run, things should be OK. If we don't break freezing today, at least we should have highs in the 30's and 40's the rest of the week. We'll still drop below 32 overnight, but that won't be as worrisome as these last several days' temps have been.
    Sandy
    15,600 gallon, screened 15x30 IG plaster sport pool with 6x8 tanning area, Aquarite SWCG, Hayward cartridge filter, Polaris 280 cleaner
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by salinda View Post
    I had the same problem so I decided to risk it and just turn off the freeze protection. Actually, it is not that much of a risk since it takes a long time, probably more than 9 hours, for water to freeze in a 2" PVC pipe so the temps here have not been below freezing for more than 9 hours at a time. Even 2" of water in the dog dish does not completely freeze (my test monitor).
    CORRECTION Just checked Yahoo weather and found out that it was below zero for 9 hours last night so I now know it takes longer than 9 hours for water to freeze (and burst) in a 2" PVC pipe. I have solar panels so some air does get into the system after the panels which probably helps some.
    Mark
    Sugar Land, Texas
    Here's a fun question for chem geek...
    What does 3500 ppm salt do to the freeze point of water?
    Pool owner - contract signed 21Aug2006; HOA approval granted; complete - existing patio demolition; excavation; rebar; embedded plumbing; gunite; plumbing; electrical; tile and coping; decking; plaster; pool fill; acid start-up; regular start-up; pool school; gas meter upgrade; additional of salt; PDA remote programming.
    Cool Re: Cold weather!!!
    Jefe, As I recall from an earlier discussion here, having salt in the water does lower the freeze temp, but only negligibly. I realize that you asked for Richard's assesment, complete with the need for some asprin or a strong drink to help the info go down( )
    Not fully trusting my memory, I did a search and found this thread https://poolforum.com/pf2/showthread.php?t=3355. On page 7 (post #62) MassAttack asks a similar ?, Radish responds (post #68) 'that the difference is negligable' and Poolsean (post #70) says that @ 3000 ppm salt the freeze temp drops from 32 to 30.7 deg (F).
    I'm sorry my answer isn't as involved as one that Richard could give, but I'd have to say that @ 3500 ppm the freeze temp will be just under 30.5 deg.
    There's the 'quick and dirty' answer, I'll leave it to Richard, or one of the other chemists to give the 'whole story'
    San Jose, CA
    Looking in hindsight at the cold winter we have had, I feel a bit of satisfaction and vindication over one thing in particular. This summer, I got a bug over the high (33-35 cents/KW-hr) rates here. We replaced a 2hp whisperflo and a Polaris booster pump with an Ikeric variable speed pump. It is not perfect. I wish that I had the Intelliflow installed instead and I also think that a robotic or even pressure-side with booster would have been more in my comfort zone, but my electric bills for this winter showed that we consistently used 300 KWhr/month LESS this year than last year. Remember the pump ran MANY more hours than last year due to the freeze conditions. Some weeks, it ran almost around the clock. Last year, maybe 2 weeks were like that. That is $100 savings per month. With winter alone, I will make back the high replacement costs I paid in no time.
    Hurray!
    Salinda
    California
    Quote Originally Posted by eljefe281 View Post
    Sorry I didn't notice this question to me before now, but the answer is, of course, disappointing. Remember that the freezing point depression for water is 1.86 ºC/m. 3500 mg/l / 58.44 g/mole / 1000 mg/g = 0.060 moles/liter which is essentially 0.060 moles/kg solvent (which is what "m" is...molality).
    So 0.060 * 1.86 = 0.11 C = 0.20 F. Yes that's right, the salt in your pool only reduces the freezing point of water by 0.2 degrees Fahrenheit.
    Richard
    KurtV is offline Registered+ Widget Weaver KurtV 0
    Mandeville, LA, USA.
    ... Well folks, this is a weird winter so far. The freeze protection has gone on every night for at least the last two months.
    It is almost 9 am and the air temp is still low enough for freeze protection. All of my hose bibs are frozen. Water poured onto the concrete patio freezes on contact. It feels like NY, where I grew up...
    I checked the water temp and the Jandy says it is 40 degrees. Is this high enough for the freeze protection to be effective? In a normal winter, the water rarely goes below 50 degrees...
    The cold weather is not expected to break soon....
    Must be global warming.
