Re: Trying to keep up w/ Chem Geek
I've been thinking... (crowd goes quiet with anticipation)...If I plum 3 panels, one after the other as the manual suggests, I will only be able to move so much water as it winds thru the panels one after the other. If I plum them in parallel, I will be able to move 3 times the water at a time. 3 times the water, more heating value?
