Results 1 to 10 of 40
Thread: Trying to keep up w/ Chem Geek
    Dec 2005
    Lakewood, CO, USA.
    Default Re: Trying to keep up w/ Chem Geek
    Believe it or not...I actually understood what Daggit was saying. I wonder, though, if you plum in a series, this non-turbulent flow is non-existant as the water flows down one side of solar tubes to a 2" pipe, hangs a right, and then flows up the other side... 3 times.
    Hate to ask it, but since we're all looking out our windows at feet and feet of snow and have nothing else to do but TALK about pools, which will get me the most hot water, turbulence (series) or flow rate (parallel)? Actually, I'm going to word it like this...which will make my pool warmer faster, as that is ultimately what I'm after.
    Shelley
    Move your pool to Puerto Rico! That will get it warmer faster!
    The issue of turbulence is unrelated to series or parallel. Plumb in parallel if you can.
    Since we are talking about solar heating, has anyone tried heating their pool with a solar system that is smaller, but is enclosed with glazing and insulation to make hotter water?
    Enclosing a solar panel that is already at 80-90% efficiency in a "greenhouse" of glass will not improve the efficiency or generate more heat. Essentially, the water flowing through the panel pulls nearly all of the energy hitting it from the sun and the panel as well as the air near it in the "greenhouse" will remain cool. Yes, I know that Carl doesn't think that my FAFCO panels are that efficient and he may be right, but more on that later -- just hang with me on this assuming that the panels are operating efficiently.
    There will be a benefit with regard to cutting down heat LOSSES if the air temperature is cooler than the water temperature, especially if there is wind.
    The reason that solar hot water heaters are enclosed in the "greenhouse" style of glass is precisely for the reason of preventing heat LOSS, not for capturing more energy. Hot water is hotter than typical air temperatures so it is important to keep the temperature around the panels as hot as the water. Insulated multi-pane glass would ideally allow most of the sun's energy through but would prevent heat loss by keeping the temperature of the air around the panels to be the same as the water flowing in the panels.
    [EDIT] It might make sense to use the "greenhouse" style for heating spa water since that is so much hotter than air (usually). I've never heard of solar used for spa heating and the raw panels are only specified to go up to around 90F though I can get my pool to around 92F if I don't tell the thermostat not to do that. I don't see why a hot-water solar "greenhouse" style panel couldn't be used for spa water though multiple panels would likely be needed since the spa has more volume (around 300-600 gallons) than a hot water heater (around 50-100 gallons) [END-EDIT]
    Essentially, you need to look at this as if there is a limited amount of energy from the sun hitting a square area on the Earth so the best way to capture more of that energy is to have a larger area of panels. This assumes that you are already at high efficiency (80%-90%), which the flat "tube" panels have if you are at their recommended flow rates of 4-8 GPM. The "floor tile" types of solar heating, like the one that Carl has, are apparently not operating near peak efficiency since increasing flow rates in his system (by his splitting into two parallel systems) increased the heat dramatically (and probably cooled the tiles down as well).
    Carl, I agree with you that the panels in my solar system should be cool to the touch even on a blistering hot day. If they are not, then they are not at 80%-90% efficiency. This summer, I'll go up to the roof to see if the panels are cool. They are connected in parallel, not in series, and right now have a flow rate of around 5.5 GPM so theoretically should be above 80% efficiency. I've never seen "steam" or "hot air wigglies" coming from the panels, but I'll go up and feel them on a hot day just to see how efficient they truly are. Though I wouldn't normally trust a manufacturer's specs, I worked with the FAFCO folks when I was getting an MBA in college and they seemed to have integrity, but then again that was over 23 years ago so there may be new players.
    By the way, my diagram was supposed to show PARALLEL panels with all bottoms of the panel piped together and all tops piped together. I'm sorry if my drawing didn't make that clear. The water (as if you are sitting on a water molecule) flows through the bottom pipe, up ONE of the panels, then through the top pipe.
    Just for the heck of it, let's calculate the maximum amount of possible solar heating capability based on the energy from the sun. The amount of solar radiation reaching the Earth's surface with the sun directly overhead (so noontime summer in northern latitudes) is around 1000 Watts per square meter of area on the Earth which is about 93 Watts per square foot (or 317 BTU/hour per square foot). You simply won't get more energy than that no matter what you do. Interestingly, the FAFCO documentation at this link claims over 1000 BTU per square foot, but that isn't BTU/hour so is equivalent to around 3-4 equivalent "peak" hours (in Florida, by the way) so they are quoting a daily BTU rate. Let's see what happens if we assume the manufacturer FAFCO is right about 80% efficiency at 4 GPM. They essentially are claiming that they are heating my pool water at 800 Watts per square meter. My 12 panels have a mixture of sizes, but the total area is 36.74 square meters (effective area). So in theory, they claim that I am getting, at noontime peak during the summer, 29,400 Watts (almost 30 killowatts) which is about 100,000 BTU/hour (about half of the 200,000 BTU/hour of my gas heater's output) and is also equivalent to 25.3 million calories per hour. 1 calorie raises 1 ml of water 1 degree Celsius. My pool is 16,000 gallons or 60.6 million millilters so that means I should expect a peak temperature increase of 0.4 degrees Celsius per hour or 0.75 degrees Fahrenheit per hour.
    I have measured the temperature rise in my pool with the solar on and I would say that APPROXIMATELY this peak temperature rise is about right. It is not, of course, a super-accurate measurement, but I would usually see about a 3 degree increase over 4 hours near noontime in June. The pool loses about 2 degrees overnight in the summer (remember that we try to keep it at 88F and have an opaque cover) and the solar typically clicks on around 10 AM (the pump starts at 9 so the solar turns on when the solar panels are warmer than the pool water) and by 1 PM or 2 PM at the latest, the pool is back to its lovely 88F. So I'm pretty certain that the panels are at least over 50% efficiency if not close to their 80%. My actual flow is more than the 4 GPM (it's closer to 5.5 GPM) so my efficiency should be higher (about 84%), but I've got the piping problem I mentioned in an earlier post that is likely causing "low flow" to three of the panels. And you are right that I should shoot for 8 GPM and 90% efficiency if I want to heat my pool a little faster -- I just need to balance that with the tradeoff of pump electricity costs.
    Richard
    You may want to check with the manufacturer to see if this is recommended or will void the warranty. It seems to me that most enclosed systems I've seen are in permanent roof-mount systems for household hot water--the "greenhouse" may well prevent freezing. But that's just a guess.
    Usually, since it's for summer swimming, it's not an issue. Even if my panels can keep my water warm when it's 50 degrees and windy out, I'm not going in! (unless I have to repair a leak--been there, done that...brrrrr! THAT will convince you that a wetsuit is great to have around!)
    Regarding the laminar vs. turbulant flow discussion, I did some calculations on that a while ago when I started looking at my piping situation and I thought it strange that the FAFCO solar panels specification showed a parabolic curve for the head loss vs. flow rate since that implies turbulant flow. I counted around 200 tubes per panels with spacing around 1/4" so at the desired 4 GPM that would be 4/200=0.02 GPM per tube. Even if the inner diameter of each tube were as low as 0.1", the Reynolds number would be 632 which should be laminar flow (which has a Reynolds number less than 2000).
    I also ran some calculations to predict head loss and could not get their results. I wrote to them about this asking them if they actually measured the head loss or if they calculated it. They wrote back (which gives them points in my book -- many vendors don't even respond to questions) and said that
    The head loss was physically measured on a sample number of collectors matched against theoretical calculations. The contributors to the overall head loss include the header pipe, small tubes, and metering plenum that evenly distributes flow to the small tubes. It appears the metering plenum is the missing component in your calculations.
    They were absolutely right. I had not accounted for the metering plenum -- I didn't even know it was there. So their tubes probably aren't that narrow in inner diameter so the flow is most certainly laminar inside those tubes, but getting from the main pipe into these tubes goes through constrictions designed to restrict overall flow rate and to evenly distribute the water and THAT is where the turbulant flow exists and is probably where the bulk of the head loss comes from (thus resulting in the parabolic curve).
    Now, interestingly, FAFCO has a dimpled version of their solar panel (see this link) called "Revolution" that causes the water in the small tubes to spiral (slowly). This makes the panel output about 5% more energy due to its higher efficiency at transferring heat from the sun to the water because the water is better "mixed" in the tubes so that it all gets heated thus having a lower temperature difference between the water and the panel itself (remember, as Carl pointed out, that the highest efficiency is achieved when there is a minimal temperature difference since that keeps the panel cooler and minimizes the radiative losses -- a cool, or at least "air temperature" panel is an efficient panel).
    Richard
    The nature of my panels makes the turbulence FAR more important than it typical Fafco roll-up panels. Fafco uses the manifold-to-tubule design to maximize the surface area exposed to water.
    I don't have the physics and fluid dynamics understanding that these other guys do, but I suspect the tubules reduce the laminar/turbulence effect.
    My panels, on the other hand, have a series of relatively large chambers, each about 2' across and 4" long by 1" high that go across the panel. The water flows like a snake from one chamber to the next and out the far end. With such relatively large passages, I suspect the laminar effect is more evident so anything that breaks that down makes them work better.
    Somewhere or other I have the FantaSea documentation about heat energy transfers of the panels.
    Mainly, much of solar heating can be handled by rules of thumb and common sense. While Richard's and Daggit's analysis will let your squeeze every BTU available out of your system, it's VERY easy to get excellent results you are DELIGHTED with using a simpler approach.
    The great thing about the roll-up panels is it is VERY easy to add another if you aren't happy with the amount of hot water you are generating. If you start by having your panels having a surface area equal to 1/3 your pool's surface area (a MUCH lower number than normally recommended--you can go down as far as 1/4 and still get good results) and set it up so you can easily add more panels (in parallel) you should be able to easily find the optimal set-up for your pool. Ah, the joys of PVC glue-on fittings, PVC pipe, and TigerFlex! I DO recommend a good solar cover when you are heating it and not swimming. It will add its own good measure by both insulating the water and by acting as a greenhouse. I've been happiest with heavier weight clear plastic covers. I don't think blue or opaque work as well.
    My pool got to 98 F last summer--I found it too hot to enjoy, but my wife believes there's ice cubes in the water (and that she can feel them!) if it's below 92 deg.
    Meanwhile my plastic welder arrived this week and I have to learn how to use it...
  1. Chem log, to see....
    By Charlie_R in forum Pool Chemistry for Intex-type Pools
    Last Post: 09-05-2012, 10:16 PM
  2. Does anyone buy chem from wholesalers?
    By pmeloy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 11-29-2011, 03:37 PM
  3. Calling All Chem Geeks (incl. THE Chem Geek) re: storing pool chems
    By elsie in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-10-2011, 11:20 PM
  4. Which chem to increase ph?
    By kelemvor in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-16-2011, 06:14 PM
  5. Chem Geek or Mbar - are you there? Iron test question.
    By labdi01 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-11-2010, 11:02 PM
