You know, I really don't know the answer to this. It SEEMS to make sense, but there will be water trapped along the edge while other water moves past it, but I'd be lying if I said I could give you a definitive answer.
I personally prefer TigerFlex because I can use glued-on fittings, which I consider far more reliable than barbed fittings and hose clamps. Yet corregated hose is VERY easy to work with and will bend to fit FAR tighter corners than T-Flex. The connections between my myriad little panels are all corregated and T-Flex would be impossible to use.
