Thread: Heater/Raypack 2100 and AutoPilot SWG
    Default Heater/Raypack 2100 and AutoPilot SWG
    I have a Raypack heater and would like to install an AutoPilot SWG. As seen in the picture below the Inflow and Out flow seem to be to narrow or close together for the SWG unit.
    Will I have any issues installing with this spacing.
    many thanks,
    New Orleans, LA
    Default Re: Heater/Raypack 2100 and AutoPilot SWG
    The image isn't showing up for me. After you get it working I would be more than happy to take a look at it for you.
    If you're trying to host the image somewhere you may want to try photobucket.com.
    Josh
    Ft Lauderdale, Fl
    slater,
    Not being able to see the photos either, as long as you install the manifold after the heater, you should be fine.
    Sean Assam
    got the picture working....thanks!
    Ft Lauderdale, Fl
    Got it. Again, plumb the manifold after the heater rather than between the inlet and outlet.
    I believe from the heater outlet it goes to a three way valve (if you have a pool/spa combination) or directly to the pool return. If it is a pool/spa combo, them plumb the manifold on the pool return side of the three way valve to avoid overchloriation of the spa.
    Sean Assam
