My appologies, I misconstrued "work with" to mean, 'will the Aquarite opperate, despite he Jandy controller', not 'will it be able to be slaved to the Jandy'.
I seem to recall, perhaps from the 'old forum', the issue of Jandy going 'proprietory' - you were probably part of that thread Sean. I've gotten into the habit of browsing the questor's previous posts (when they are less than ~20 - 30) for any extra info about thier pool -- In this case I discovered that Boscogabby was converting a liner pool from Baq and planning on installing the Aquarite last June, so I assumed that he had the unit and wondered if it would operate despite the incompatability of the software. Having the remote 'talk to' the SWCG is cool, but not necessary for operation (though if I had to physically get up to change the TV channels or volume, I'd be upset after so many years of just pointing the remote at it)
Boscogabby, in response to your follow up ? - yes, the only reason was for the poolside handheld remote, if your chip is one that Sean mentioned, the 2 units should play nicely together.
