I've said it before and I will say it again, water temp makes a difference. If you compare test results done of 75 deg water and 45 deg water you will be comparing apples to oranges! Taylor doesn't really specify a temp at which the tests should be done (to the best of my knowledge) but LaMotte does state that their reagents are formulated to produce accurate results between 70 and 80 degrees.
