Results 1 to 10 of 10
Thread: ICE Level getting too close! HELP
    Honesdale PA
    Default Re: ICE Level getting too close! HELP
    Jans comments are correct. I only drain mine to mid-skimmer level so with snow and ice, like today, the level will go up. Trying to drain at this time would be more of a risk because the massive ice block can do damage.
    Edit: I found the duplicate post and Carls response. To restate...be careful if you drain with a large ice block in the pool. That's a lot of weight and if thick enough it can damage stairs or even shear off the return jets if they protrude into the pool even a little...as they usually do. I force a rectangular piece of foam in the skimmer throat so ice can't creep into the throat. I have drained mine with a thick ice block but do it very slowly, maybe 1/4" every day and I do keep a close eye on problem areas.
    Joe, you've gotten good advice from 3/4 of the moderators (Watermom didn't 'chime in') - listen to it! If you closed the pool, as advocateded here, which you said you did, you shouldn't have any problems. I do want to point out that ~10" of snow = 1" of water, so don't drain too much water out of your pool (you've got a mesh cover, so try to keep it out of the pool water.) If you want to drain some, you can use calcium flakes (~77%) to melt a hole in the ice into which you could put a 'sump pump' to drain some of the water out of the pool, but I doubt it's needed, perhaps there are some pools that need constant attention over the winter, but I doubt that yours needs that sort of scrutiny.
    We've met before, and I'd hope you would trust me, but I think your pool will be fine come spring.
    You are right to trust the good folks here, and I hope you continiue to do so!
    jmjbj_h Guest
    Thank all of you so much for the timely advice. I was wondering if the block of ice may ruin my returns, stairs, etc. if I drained it too much. I think my plan will be to run an get a sump and some 1/2" hose in case I have to move quickly, only drain a small amount at a time, and hope that I don't have to use either! I will update this with my results.
    tonyl is offline Registered+ Thread Analyst tonyl 0
    Indiana
    I also have the permeable mesh cover and try to keep the water level just below the cover, about mid skimmer level with some foam stuffed in the skimmer opening.
    Keeping the water level up will allow the cover to sag onto the surface of the water (or ice in this case) in times of heavy snow and ice.
    I have several bent springs I replaced before I learned a higher water level is a supporting surface and helps prevent wear and tear on the cover.
    Hope this helps, Tony
