We have a 10k gal 12x24 IG pool with a DE filter.
Our pump failed for about a week, and in that time we got some algae in the pool, and the water went green. We got the pump going again and took the DE filter apart and cleaned it (something we've done several times). Usually the pool clears itself up again within a few days. But a week later, we noticed that the pressure was off the scale and the water was so dark green you couldn't see more than a couple of inches through it.
This weekend we took the filter apart again and cleaned it all, but the pressure will max out within about 15 minutes. We've tried backwashing every hour all day long today, but when we put it back in filter mode, the pressure climbs up over the max again > 30PSI in under 15 minutes.
During backwashing the pressure is pretty low ~ 5PSI and you can see the water rushing through the skimmer. When back in filter mode the water gradually slows down until the pressure maxes out and then nothing is flowing through the skimmer.
Any ideas how to fix this problem? We're close to just draining the pool completely and staring over from square one.
