Re: Help needed - Replacement pool/spa heater
Kelly,
The system is low pressure. I am going to call the utility to see if they can change it to high. This should take care of my issue and bee les expensive (?) than a new heater, I assume.
If I do this, do I I need to put a regulator at each device (pool heter, gas furnaces, gas cooktop, grill) or one at the heater, one at the gas entrance to the house (vs at each gas furnace, cooktop, etc. in the house) and one at my grill?
BTW, I used Mirage Pools who I foudn through a recommendation from you. While we are happy overall with the end result, we had quite a few glitches that only persistance on my part got fixed by Mirage. This heater issue has been going on since day one, but since it is intermittent, and "should" work per the deign constraints, Mirage has basically blown me off. Since it's been well over two years since the pool was done, I don't even try to talk with those guys anymore.
KLnow any good pool service companies in North Dallas/Plano? The guy that worked with Mirage is not very responsive and I have a slightly leaky pump as well as the heater thing
