mas985
Why did they spec the main pump at 2 HP? The only reason I would go with a 2 HP main pump is because the pool has a spa that shares the pump. Is this the case? Also, what size is the pool? Depending on the spa and pool sizes, there are probably several options. 2 speed pump is one option but you could also go with separate pumps for the spa and pool which may be better for larger pools. Key parameters for pump decisions are:
Pool Size (gallons)
Spa and number of Jets
Piping size and number of pool to pad runs
As for the water features, I decided against them for my pool. You may be aware of this already but the water features combined with a SWG usually means the pool will continuously have rapidly rising PH levels. Be prepared to have a lot of acid on hand. Mine rises fairly quickly even without the water features (1qt/week in summer). Also, water features will increase evaporation rates so be prepared for a large water bill as well. Water features are great eye candy but they come at a cost.
