Results 1 to 10 of 24
Thread: 2 speed pump or not? Also the great DE debate!
    mas985's Avatar
    Pleasanton, CA
    Default Re: 2 speed pump or not? Also the great DE debate!
    What I mean by pool to pad runs are separate pipes from the main drain to the pad and skimmer to the pad or does he combine the runs at the pool and bring only one pipe back to the pad? Same for the return side, single pipe from pad to pool or multiple pipes?
    Anyway, your pool size and plumbing is similar to mine. I went with separate pumps for the pool and spa (jets). This way you can have the jets going while the pool is in circulation if required. I have solar so it is nice to heat the spa up with the solar and then switch the circulation back to the pool to continue heating while I just use the jets on the spa. Also, this allows you to size the pump for just circulation and the spa just for the jets. You could go with a 3/4 single speed and save a bundle on electricity costs. A 2 speed 3/4 HP would save even more. So in summary, here is what I see as your options:
    2 Speed 2 HP pump for both spa and pool - Saves some in electricity
    OR
    3/4 HP pump for pool and 2 HP pump for spa jets - Save some in electricity but adds circulation flexibility.
    OR
    2 speed 3/4 HP pump for pool and 2 HP pump for spa jets - Saves even more in electricity and maintains flexibility.
    OR
    Intelliflow pump for most flexibility - Saves most in electricity but without separate spa jet pump although you could add that too $$$$.
    The last option is probably not much more than the second to last option and would give you multiple speeds for the spa jets as well.
    There are pros and cons for each option and really depends on what you are looking for.
    Mark
    Just a caution on the Starite system 3 filters. Check the cost of replacement media for it! (Especially the modular [cartridge element] and modular DE [DE/cartridge element]. The system 3 vertical grid DE does not have quite as much filter area as the DE/modular combo but it is a plain DE filter and will be probably more cost effective!) You might find the replacement media to be VERY expensive compared to some comparable filters!
    Personally, I like Pentair branded filters. They use a standard type of filter media and replacements are available from most of the third party manufacturers! (but stay away from the Clean and Clear Plus if you go with cartridge, stick to a single cartridge unit!) Pentiar DE filters are excellent also and have a more standard design.
    (Starite is owned by Pentair, btw!)
    North Florida
    I wholeheartedly agree with waterbear's comments on the cost of StaRite's System 3 cartridges!!!
    I read about some cartridge owners having a spare set so you could just switch the sets at cleaning time and take your time cleaning the ones you took out. Sounded like a good plan to me, especially if they needed soaking. Then, last summer, I looked at several websites to price the replacement filter elements and got sticker shock! The system has 2 cartridges. The smaller one ran from $92.95 to $149.99, depending on the site and the larger one ran from $183.95 to $239.99. That's $276.90 to $389.98 per set!!!
    I'm going with just my original set for now and trying to take VERY good care of it...
    Sandy
    skamp is offline Registered+ Thread Analyst skamp 0
    Cypress, TX
    Quote Originally Posted by dawndenise View Post
    That is quite a bit of money! I will make sure to take good care of my filter. Looks like the DE replacement is about $250.00. Thanks!
    the woodlands, texas.
    A 2 speed pump is great for affordable day in and day out circulation while still having a high speed for the spa and the pool sweep.
    I really don't recommend them on water features because they gobble up relay spaces.
    On your DE -vs- multi cartridge filter question I'd suggest the FNS 60 or Clean and Clear 520 over the StaRite product. Those StaRite filters are indeed great but don't use industry standard grids or replacement elements.
    See ya,
    Kelly
    Quote Originally Posted by huskyrider View Post
    See ya,
    Kelly
    Kelly, the Clean and Clear plus 520 by Pentair is a 4 cartridge unit. This are a horror to clean and, IMHO, is WAY oversized for a 20k pool! The Clean and Clear 150 has exaxtly the same residential flow rate and turnover capacity and just uses one larger cartridge so it makes maintenance much easier and cartrdge replacement expense much lower. Granted the 150 only has 150 sq in of filter area compared to the 520 sq in of the plus model and only about 1/3 the commercial flow rate but it should be more than adequite for this installation, if not oversized! (a good idea with cartridge filters). If the commercial flow rate is what you are basing it on the Clean and Clear 200 has a commercial flow rate of 75 gpm and all three of this filters have a manufacturer's turnover rate of 48 k gallons in 8 hours so this would be over 2 times the pool volume.
    The Pentair FNS series DE filters are excellent, IMHO but do you really think a pool of this size needs the 60 sq in filter? Based on turnover capacity I would think the FNS 48 would be more than adequite.
    Evan
    Just my 2 cents!
    Just as two lawyers interpret a law differently so do pool professionals.
    The larger filter will easily go a full swim season before it needs cleaning and is rated for a much higher flow rate than one with a third of the swept area.
    I'm not saying that the 150 isn't adequate because it is. I use larger filters so the buyer can clean in April and October. IMO, the 150 owner will be cleaning much more often than the 520's owner. I'd rather clean more elements less times than one element more times.
    What I've found is that most buyers completely forget about their filters. When they call me back every time the filter gets dirty it's assumed that I'll clean it for free until the end of the first year. I find it easier to pay more for the bigger filter knowing it'll go years without cleaning if necessary.
    I've seen lackadaisical homeowners who'll go 3 or more years without cleaning their filter. These large multi-cart filters will circulate even with more dirt in them than you can put in a full size wheelbarrow. I've seen it firsthand on many occasions.
    I'm not trying to imply that all homeowners are the same, I'm going by what I've seen year in and year out. I've had plenty of homeowners who'd just assume not clean and simply pay to have the elements cleaned or replaced. For those the larger filter makes perfect sense. You don't have to pay for filter cleans as often. In our area a filter cleaning costs the same whether it's one element or 4 elements. If I were in the service and repair business in addition to pool construction I'd install smaller filters and cross my fingers that I get the call every time the element gets dirty and needs cleaning.
    See ya,
    Kelly
    Ok, here's my take.
    First: If you can afford it a 2 speed filter is ALWAYS the way to go. Mine has a simple Hi-Lo switch on the back of the motor. You can ALWAYS run the pump at full speed should you not be happy with lo. But lo is quieter and cheaper.
    Second: PBs and pool salesmen LOVE to sell oversized pumps. Go to PoolSolutions.com and read the tip on "The bigger Pump scam". I have 20,000 gal rectangular A/G with a deep end and I use a 1 hp Hayward SuperPump 2 speed--with solar panel, and run it at low speed 95% of the time. Other brands make 3/4 hp 2 speeds that spec out just as good as the Hayward.
    Third: a properly sized and maintained filter of ANY type can keep your water clear. PBs love carts--I think they must be high margin, they are an easy install, and for most of the first season they don't need to be cleaned. IF you can figure out how to clean them without making it a half-day soaking-wet job you may be delighted with them.
    For DE, they do a WONDERFUL job, but I suspect the consensus here is that an ordinary one, sized properly, will do just as well as a gadgety one, and will be far cheaper to maintain.
    You weren't even interested in sand but sand can also perform far better than they lead you to believe. If your sand filter is slightly oversized (mine is) at low speed on your pump in cleans better. As the sand gets older and dirtier, it also filters better. Finally, adding a little DE powder after you back wash will down-right POLISH your water--and I've gone 2 seasons already on an $8. box of DE. You cannot add DE to a cartridge. (there is a fiber substitute for DE that you can use in a cartridge).
    You should also use "skimmer socks" in your skimmer with any filter. They go in like a Mr. Coffee filter and hook over it. I find they last about a month and reduce the load on the filter by stopping stuff at the skimmer. Skimmer socks are usually about 3 for $5 or 4 for $10 depending on the brand and the store. Some people use old panty hose but I suspect it doesn't filter nearly as well.
    But I think the advice you've gotten here on 2 speed pumps and pump sizing before I chimed in was just right on the money. It's your pool, not the pool builder's.
    Since it looks like a concrete/shotcrete/tile/plaster pool, you may want to use Tri-Chlor pucks early on. They add acid and stabilizer(CYA) which you will need. When CYA hits your target level (generally max 50ppm) you'll stop using the pucks.
    Cypress, TX
    Wow, great info. I really appreciate all the help on this. Thanks!
    simsjim is offline Registered+ Thread Analyst simsjim 0
    Jul 2006
    Ok, here's my take.
    If your sand filter is slightly oversized (mine is) at low speed on your pump in cleans better. As the sand gets older and dirtier, it also filters better. Finally, adding a little DE powder after you back wash will down-right POLISH your water--and I've gone 2 seasons already on an $8. box of DE. .
    VERY Interesting, and helpful! see my thread on "Pentair pump filter to replace Hayward" Gives me more food for thought......
