Re: Looking for Advice - Possible SWG Convert
I don't believe there's a direct correlation between filtering times and chlorination with or without a SWG. I've had the AquaRite for several years and have not had to adjust my filtering times when using the generator. My pool is 20k,ig, vinyl and in the heat of the summer here in Indiana the timer is set for 8 hours.
One thing you might consider is that the AquaRite runs on a 100 minute cycle. So....if you're running a 4 hour morning cycle and have the Aquarite set for 50% you won't get the full end cycle. In other words, from 1-100 minutes, will run for 50 minutes, 100-200 minutes, 50 minutes, 200-240 minutes will only get you 40 minutes, obviously. Not a big deal but the only example I can think of when you might want to bump up the filtering a few minutes.
Hope this helps, Tony
