Re: Looking for Advice - Possible SWG Convert
2,3,4 even up to a week?
Well actually....there's been several times I've left my pool untouched for TWO weeks since I've had a SWG with no problems whatsoever. The only thing I do when leaving for that long is to close the skimmer valve in case evaporation or a leak takes it down below where it can draw. Main drain only is no problem as long as the pump gasket doesn't leak and I always check it out.
Welcome back Pat! Hope all is well with you.
Tony
