Results 11 to 12 of 12
Thread: New build, plaster question...
    GutierrezPlastering Guest
    Default Re: New build, plaster question...
    By the way that white streak that is running down by your waterfall i would request your contractor to straight acid wash it because it may bleed through and you will see the discoloration in your plaster. It would be better to play safe then sorry.
    steveinaz is offline Lifetime Member Weir Watcher steveinaz 2 stars steveinaz 2 stars
    Southern Arizona
    Ok, will do thanks.
