What is your Total Alk, and do you have a waterfall/fountain/anything else that aerates the pool water? Aeration of the pool water will make your pH rise, although at what rate really depends on your alk. Also, what form of chlorine are you using? Bleach has a higher pH, while trichlor/dichlor is lower. Depending on your CYA level, you could use trichlor to help chlorinate and keep the pH down, until yourCYA level rises to where you want it.
What is the pH of your fill water? Some pools have a pH at which they like to "stay"....if left alone, the pH in my pool will invariably go to 7.8 and then stay there....unless I'm using trichlor or acid. In that case, it's just easier to live with a slightly higher pH than it is to fight it.
