Re: Clean up of blood
I assume you mean in the pool water.
You want to shock your water up to the recommended shock level for your level of stabilizer (CYA).
I suggest you keep it there for 24-48 hours, to see if the FC stays high AND to ensure you have a CC level of 0.
Essentially, you want to follow the same procedure as for fecal matter in the pool.
If someone has a better or more specific rec, please post it.
Blood on the deck, etc. can be cleaned up with bleach.
