Thread: Cleaning My Sand Filter
    rilesworld is offline ** No working email address ** rilesworld 0
    Nashville, TN
    Default Cleaning My Sand Filter
    I have a Hayward S200 sand filter that makes noise when the pump is turned on. It sounds like there are 2-3 rocks inside the filter that proceed to bang around when water starts to flow through it. Is this something to worry about? Can I just take the filter apart and look inside and remove any foreign objects if I see them, or is there a little more too it than that? I am a new pool owner and am leary about just taking things apart.
    I downloaded the manual but that didn't seem to help.
    Thanks,
    Jeff
    Jul 2006
    Default Re: Cleaning My Sand Filter
    Did you try to backwash your filter?
    Honesdale PA
    Nothing magic to taking it apart and looking but I suspect all you have are air bubbles trapped in the valve assembly. Makes a rattling noise like you describe. My valve is top mounted but it makes no difference. Mine makes the noise once in a while and eventually clears itself. Sometimes I'll just crack the multiport valve handle just a little bit with the pump running to open all ports and that helps bleed any trapped air. When I say just a little I mean it. Raise the handle too much and you run the risk of the spider gasket popping loose.
    Hope this helps.
    BTW: Jeff, welcome to the forum.
  1. Operating & Cleaning a DE filter
    By packerfan in forum Pool Equipment & Operations
    Last Post: 05-03-2018, 08:54 PM
  2. Cleaning Sand vs Replacing
    By gardengirl in forum Pool Equipment & Operations
    Last Post: 06-20-2008, 11:40 PM
  3. cleaning DE filter
    By borrott in forum Pool Equipment & Operations
    Last Post: 11-05-2007, 02:13 PM
  4. Cleaning a DE Filter
    By Steve #1 in forum Pool Equipment & Operations
    Last Post: 06-14-2007, 01:23 AM
  5. DE Filter Cleaning
    By jimgregory in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 07-14-2006, 11:15 PM
