Results 1 to 10 of 11
Thread: Replaster job
    ehorn is offline Registered+ Thread Analyst ehorn 0
    Tucson, AZ, USA.
    Default Re: Replaster job
    A 6 - 8 hour filter time is good. Mark makes a good point about filtering more while the plaster is curing I'm sure it can't hurt to run it longer while that is occuring. After the plaster is cured most pool companies will set you up with a 6 - 8 hour run time, I was told 6 hours is good in the winter and 8 hours in the summer.
    If you want to get technical you look at the size of your pool and the gallons per hour your pool will pump. You want to exchange at least the volume of the pool once a day, that is a minimum.
    Oh also the guy who did the startup on my pool recommended running it at night. I guess that is to use the pumps when the electricity is the cheapest and also when its the coldest. If you freeze at night sometimes running the pumps will prevent any freezing of the water in the system.
    Of course I'm thinking of adding a solar system so that will change everything since I'll need to circulate the water during the daytime to heat the pool. So many considerations.
    Eric
    Columbia, SC
    Thanks for the prompt replies and all the info. Next question: How long after new plaster/refill can we wait for the water to be balanced by PB? I love this site. Joyce
    18,000 IG Gunite/Plaster, Hayward Sand Filter
    mas985's Avatar
    Pleasanton, CA
    I would not wait for your PB to balance otherwise you may end up with a rough surface or deposits. This can happen when the PH and Alk are too high.
    So I would get the PH and Alk in line as soon as possible. I kept mine around PH 7.2 and alk 80 to keep some of the dust in solution to more easily filter it out. This reduces the dependency a bit on brushing.
    Also, chlorine will help keep the algae out so I would do that right away too.
    Mark
    Columbia, SC
    Hi, and thanks. PB just came and put in four gals of muritic acid and left. Don't know what their balancing plan is, but does this seem like a good first step? Thanks again, Joyce
    Tucson, AZ, USA.
    Wow 4 gallons of acid, that seems very excessive. Not sure why they would add that much unless the PH was SUPER high. I have a pebble tec finish so I'm not sure what is all required for plaster. Usually you put acid in a quart or two at a time to reduce your PH.
    You usually don't need to worry about adding chlorine or stabalizer if you water temperature is cold which is usually under 55 or 50 degrees.
    So anyways I'm kind of at a loss as to why so much acid was needed.
    Eric
    mas985's Avatar
    Pleasanton, CA
    It sounds similar to what I did when I started my plaster pool. I was debating about doing an acid start or a chlorine start for the plaster.
    A chlorine start is a basic balance of the water after fill and is very low risk. The downside is that you have to deal with the plaster dust. Most plaster pools are started this way.
    An acid start drops the Alk to 0 for about three days and basically dissolves all of the calcium dust in the pool. It is pretty risky unless you know what you are doing. It is pretty easy to get it wrong and damage the plaster. As you bring the PH up, some of the calcium drops out of solution but it is slow enough that the filter can catch most of it. However, I believe that a true acid start would have required more acid than what your PB put in.
    I chose a middle ground and droped the PH down to about 6.8 for about a week which limited the dust somewhat but I did not need to worry about scaling or damaging the surface. It sounds as though this is what your PB may be aiming for or something slightly more aggressive. After a few days, I would check it to make sure the PH is rising and is at least about 6.8.
    Mark
    Columbia, SC
    Thanks. We will keep check on progress. We are brushing every day and filtering 10 to 12 hrs per day. Our water temp was 52 this morn, so it is starting to ease up, which we will watch too. Will keep posting with any new plaster issues until water is okay-good-great. Love this site. Thanks, Joyce
