Is this a pressure or vacuum cleaner? You said return which indicates a pressure side cleaner. What Poconos suggested will work well for a vacuum cleaner but you may need to glue the pipes together and have threads for a pressure side cleaner. However, that means you will have a pipe sticking out in your pool all of the time.
) If you don't have all the tools to reshape a peice of pipe, you can find them {edit - pipe extenders} online (I'm sure that the link I gave is not the only place to find one - knowing that they exist is the starting point for comparative shopping) Before gluing anything into the 'return', double check that you need to (the old owners might have left the attachment fitting you need), and be sure that it's a return driven cleaner -as mas pointed out. Run the pool a few times and see if the cleaner will work without permanently having something stick out into the pool - or if you can contact the old owners, ask them what they used.
) No one where I work had ever heard of 'pipe extenders' until I had the secretary order some - who knows what fittings exist that I don't know about!?
) - Waste
