Results 1 to 8 of 8
Thread: Quick Question About pH DROPPING???
    PopcornGirl is offline ** No working email address ** Thread Analyst PopcornGirl 0
    Baton Rouge, LA
    Question Quick Question About pH DROPPING???
    At first I thought it was just a mistake on my part, but I have triple checked it and my pH is definitely coming down.
    Two days ago it was 7.5, yesterday & this morning it was 7.4; just checked it again (3 times to be sure) and it is 7.2.
    As some of you know, I am coming off a LOT of problems and am currently rebuilding the chlorine in my pool after a HEAVY demand. I'm still trying to get to 20 ppm. (Please see the EASTER EGG thread in this forum for more info)
    I guess my question is this:
    1) Is this NORMAL???
    and
    2) Will this interfere in any way with my bleach shocking/conversion?
    I know that the pH doesn't really need to be any lower than 7.2 and I have NOT added acid or anything BUT bleach for the past several days...
    My CYA is currently at 50.
    Should I be concerned or no worries?
    Katy, TX
    Default Re: Quick Question About pH DROPPING???
    Well, without reading the other thread, do you have a puck-based Cl feeder running?
    Start adding borax if it gets to 7.0
    Michael
    duraleigh Guest
    Summer,
    No worries. I can't explain why it's occuring but, as Michael said, it's easy to control. Use his calc to see how much acid you need to bring it back into range.
    It'll have no affect on your Cl application. We'll help you get your pool fine-tuned after that Cl holds overnight.
    You'll love Bens' kit....it's money well spent.
    Baton Rouge, LA
    I can't wait to get it!
    Well it's good to know that it won't affect the chlorination, but what I was really hoping to find out was *why* this is happening.
    Does anyone know what is causing this?
    I'm really wanting to better understand all these chemical relationships...
    Have you had a lot of rain? Whenever I do, I sometimes see a drop in ph.
    Watermom
    mbar's Avatar
    Ashland, PA
    I think it is still left over from your stain treatment. What is your alkalinity? Post your numbers if you can. The stain treatment is very acidic, and can be effecting your ph. You may want to keep your ph at 7.2 for now - it will help your chlorine to be stronger, plus it will help keep any metals that are in your water from dropping out and landing on the surface of the pool again. Your chlorine is still fighting something that's why it's getting eaten up. Keep an eye on your ph, and try to keep it at 7.2 to 7.4. Your ph will stabalize once the chlorine is finished cleaning up and filtering out what shouldn't be in the pool. Check your alkalinity, because you can also get into ph bounce - all of the chemicals work together, that's why it's great once the pool is balanced - and don't worry you will get there!!!
    Northeast PA
    Baton Rouge, LA
    Watermom,
    Unfortuantely, NO -- it's been EXTREMELY DRY here.
    We had a brief thunderstorm today that gave us a pretty good soaking, but that's the first one in about 2 weeks.
    Marie,
    THANK YOU! That's what I wanted to know & needed to hear... I will stop worrying now.
    My current pool readings are:
    Temp: 78 degrees (must have been a cold rain!)
    FC: ~10 ppm
    TC: ~8-9 ppm
    pH: 7.2
    Do I need to check TA & CYA again? They were both fine 2 days ago...
    I will if I need to!
    I have a regular chemistry lab set up on my dining room table.
    Thanks again for the help,
    mbar's Avatar
    Ashland, PA
    I would check them to see if they changed at all. It is good to see what your cya is because it will change how much chlorine you need to get into shock. You want to check your alkalinity because the stain treatment can mess that up too. You are certainly on the right path - your pool looks beautiful, once all the algae is gone and you can get your water in balance, it will be a cinch to keep it that way.
    Northeast PA
  1. Introduction & Quick Question
    By Scarfie in forum Above-Ground Pool Construction & Repair
    Last Post: 06-15-2011, 09:54 AM
  2. quick leveling question...
    By badutahboy in forum Above-Ground Pool Construction & Repair
    Last Post: 05-17-2007, 07:56 AM
  3. Quick CYA question
    By doggie in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-15-2007, 02:15 PM
  4. Quick Question ???
    By IMherDad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-25-2007, 03:57 AM
  5. Please help - quick question - is soda ash OK?
    By haeffnkr in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-20-2006, 12:09 AM
