Thread: Pump sizing query
    Sumo1 is offline Registered+ Weir Watcher Sumo1 0
    Default Pump sizing query
    I've been shopping for a two speed pump and have looked at some online pool schools to try to get the right size. For about 27000 gal and 8hr turnover, I figure I need about 56gpm minimum flow rate. My max plumbing flow is 73gpm and best flow rate for my filter would be about 72gpm. Thus the ideal flow rating should be 72/73gpm. Have I done that right? I've been looking at the Whisperflo 2hp uprated and 2hp full rated but haven't been able to find what their flow rates are. Can anyone help guide me here, or could I drop back to a 1.5hp? I don't think I can swing the extra dinero for Intelliflo. I'm assuming a TDH in the 60s. Thanks! Hal
    20x40 IG gunite free form, approx. 27K gal, 60sq DE filter, Jandy Stealth 2hp 2speed pump, Polaris 380, SWCG
    mas985's Avatar
    Pleasanton, CA
    Default Re: Pump sizing query
    Pump flow rates are determined by the amount of head loss in your plumbing. For a Whisperflow, a TDH of 60 will give you over 110 GPM for a 2 HP. If you only ned 56 GPM, then you only need a 1/2 HP or 3/4 HP. Here are the pump head curves:
    http://www.poolplaza.com/WhisperFlo-techspecs.shtml
    The lower the HP, the lower your TDH and GPM will be.
    However, since you have a spa, you may need the higher HP for the jets, assuming the pump runs both. If so, then I would go with a 2 HP 2 speed pump to get the high HP for the jets and the low speed for general circulation.
    Another option, if you have extra cash to burn, is the Intelliflow 4x160. This will give you 4 settable speeds to customize the exact flow rates you need.
    Mark
    I've found a really good price on a Hayward MaxFlo 1.5hp twospeed. Do you think there would be much difference between 2hp versus 1.5hp when running the spa? Hal
    mas985's Avatar
    Pleasanton, CA
    It is hard to say if there will be a significant difference. You really have to compare the braking HP of each pump which is the service factor times the label HP. If they are close, there probably will be minimal difference. Your GE pump should have a service factor listed on the label. Usually older pumps have lower SF than newer pumps.
    The MaxFlo pump is speced as an uprated pump which means that a 1.5 HP uprated pump is really a 1.0 HP full rated pump. So it is likely to be much less powerful than your current pump. In addition, the MaxFlo pumps, despite it's name, tend to be low head and low flow pumps. At 50 feet of head, this pump will only output about 50 GPM which is much too low for a spa.
    I would stick with one of the high efficiency pumps such as the Hayward Northstar, Pentair Whisperflow or Sta-Rite MaxEPro. Even though these cost more money, over the life of the pump you will more than pay for the cost difference in electricity savings.
    Mark
    Thanks, Mark. That's a great answer. In fact, I read some literature about the MaxFlo that showed me the low flow rate you mentioned. Now I'm back to leaning toward the Whisperflo 2hp 2sp (#011524). I called a Pentair dealer and he said that on low speed at 60 ft of head, it would flow between 50 and 60 gpm, and about 120gpm on high. However, isn't the high speed flow rate irrelevent since my 2inch pipe only flows 73gpm max?Thanks....Hal
    PS: This pump is an uprated 2hp.
    mas985's Avatar
    Pleasanton, CA
    On low speed you won't have 60 ft of head. The dealer probably meant that with 60 feet of head at high speed at low speed it would deliver 50 GPM. Pump affinity laws tell us that:
    The head on low speed will be 1/4 of the head at high speed
    The GPM at low speed will be 1/2 of the GPM at high speed
    So if you have 60 feet of head currently with a 2HP uprated pump, then according to the pump head curve shown here, the Whisperflow should perform as follows:
    High speed head = 60 ft.
    High speed flow = 100 GPM
    Low speed head = 15 ft.
    Low speed flow = 50 GPM
    The flow rate of the pipes are recommendations not actual limits. Although very inefficient, you can go way above those values without too much problem. However, the pipes will wear out faster but it should happen over a fairly long period of time.
    Mark
  1. Pump Sizing Question
    By BigDave in forum Pool Equipment & Operations
    Last Post: 06-23-2011, 03:34 PM
  2. Pump and filter sizing
    By wsommariva in forum Pool Equipment & Operations
    Last Post: 05-23-2011, 12:37 PM
  3. Question on PB's pump sizing
    By txborn in forum Pool Equipment & Operations
    Last Post: 10-27-2006, 02:26 AM
  4. Pump sizing for filter
    By derrikm in forum Pool Equipment & Operations
    Last Post: 09-18-2006, 08:05 PM
  5. Pump Sizing Question
    By liz+3 in forum Pool Equipment & Operations
    Last Post: 06-27-2006, 10:45 PM
